![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
I wonder why in the instructions they give and also if you ask them personally, why they don't say anything about cutting the stops. I've been doing some reading and it seems that the TRD springs are a bit stiffer then the other springs of choice, so that it's much less of a deal about bottoming out, terrible ride, etc.
#2 | |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Before I put on my TRD shocks, the ride quality was not very good. Almost every time I went over a bump, my rear shocks (after the springs had settled) made this crashing sound. After the TRD shocks, no issues at all. And I never cut the bumpstops. Now, if you can't really afford the TRD shocks, and they are admittedly a bit pricey, you can opt for the Tokico sport shocks from yarisuniverse.com. They're $306 including shipping.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
There's a DIY (or was) on here on how to install lowering springs. I did cut my bumpstops just like it described and had no problems at all. If you do not cut them, the car will not lower in the front like it's designed to do with them installed.
BTW, I found the original TRD box with the packing slip still attached from TRD Sparks and have your springs boxed. I will be shipping in just a bit. I'll PM you with a tracking number very soon.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
Well, this isn't 100% true. They will lower after their settling-in period. Granted, with the stock shocks, they won't lower as much as when you put performance shocks in; in which case it's uneccessary to cut the bumpstops. If you do keep the stock shocks, you should cut them.
| TRD Springs Shocks and Sway Bars IN STOCK | Sparks Toyota-TRD | Sparks Toyota | 0 | 03-12-2009 09:54 AM |
| Yaris is low enough stock....trd springs bad??? | Yawesh | General Yaris / Vitz Discussion | 13 | 12-26-2008 12:17 AM |
| Free for Local Pickup: Stock Springs, Shocks & Struts | Violin | Items for Sale by private party | 4 | 11-14-2008 09:36 PM |
| using the tops from stock struts with new trd struts? | tekmoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 01-13-2007 11:58 AM |
| ordered my trd springs and trd struts earlier today | tekmoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 01-10-2007 06:36 AM |
