#1 | |
Break'em off some.
If not, then he could be right. I have a knockbox that we could listen to the engine with and see if it is indeed knocking. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Where in the OC are you? If I don't chicken out due to this AFR, I might just run into you at Willow Springs on April 10. You can see what the car is doing on and off boost.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Break'em off some.
Break'em off some.
What are the pinouts for the black box and does it connect to the boost switch? my guess is yes.
The next step is who is brave enough to disconnect a couple wires and find out exactly what the black box does :) |
Break'em off some.
OK I found the pinouts for the black box. It just connect to fuel related components. We will have to do some data logging to see why the car is pulling timing under boost.
Long, If you can, warm up your car and do a couple pulls in 2nd or 3rd. Then pull the negative battery connector, or pull the fuse to the ECU. Pump the brakes a few times and reconnect the fuse or battery. Go out and do another couple pulls and see if the timing you see increases, or increases and then decreases. Let us know the differences. |
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 12:10 PM |
