![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Turbo Questions
I've seen turbos done good and bad. For me the beauty of a turbo is that it doesn't affect MPG unless you rev high. A turbo setup done right can have great everyday driveablity and you never know its there unless you need it. The big issue I have found with Turbos is the ECM. With my 93 Civic it was easy, the ECU code was hacked and it could be changed. In my state (Pennsylvania) they scan the ODBII for inspection, no problem with the old Civic.
Not interested in a supercharger, they are fine for racing, but just rob too much fuel economy for my tastes. With a turbo you basically get boost only when you need it if its done right. What are the options with the Yaris? Can you add maybe 5psi, pass OBDII, and still get 40 mpg if you stay under 3500 rpm? Are there any one stop packages? If not, I'm sure there will be in a few years. Just interested to know whats out there. |
look around this sub-forum, for the moment there's no simple plug-and-play kind of solution for the electronics. Turbo hardware is not a problem, with the right choice of turbo unit you can get it to start boosting at whatever RPM you want... but the software is the thorn in our side...
What about bigger injectors and stock ECU with a mild boost, any success with this? If not I can wait, I am sure the ECU will be hacked eventually, this car will be a cult classic like the old Hondas in 5 years.
Who said Yaris was slow?
The stock injectors should be more than enough for 5psi...
The problem is that after you have gone thru all the trouble and custom work... who in their right mind would not want more!! ![]() But seriously... If you carefully select a turbo that will spool at 3,500-4,500 rpm's throw in colder plugs and run it with premiun gas... you should be more than able to get away with the stock ECU and no tunning... At that psi level you won't even need an intercooler... so less things to worry about... no piping or leaks... Garm ( Caliyaris ) has been running with no tunning for 8 months boosting 8 psi and he has not killed the engine... he is running lean at WOT but that is to be expected. But if you are truely able to stick to the 5 psi boost level... you should be more than fine. You could probably achive around 130 whp with such set up... which is more than what the blitz puts out... and it would cost way less... It would not have the instant response of the SC, but that is not waht you are looking for any ways... If you have some skills you should be able to do it with less than $1,000 I predict that the Yaris ECU will not be cracked in 5 years, nor in 10 years... Just rembember... anything more than those 5psi and you will be on the same boat as everyone else on the Force Induction area... Tunning problems as there is no easy way to modify fuel and timing on these cars... |
Bathroom + Laptop = <3
Wait, i have a question Castrex since you seem to know alot. What AFR is Cali running in boost, and I have a K03, will the low end torque end up killing the rods because of the quick spool? I really want to turbo the yaris, even if i don't add a BOV or intercooler etc, like Richards kit
#7 | |
And no, you won't throw a rod... a K03 will not spool any faster nor provide as much power/ torque as Garms GT25R and he has not break anything so why would you? Then again... what I'm trying to say is that if you are not looking to go near the limits and you can be satisfied with a low boost set up... you could do it with no tunning.... 4-5 psi no intercooler... or a small one And a cheap small turbo like the K03 or even a bit larger turbo if yoou want it to spool later... perhaps a take off from a wrx... stock injectors or some just a tad lager like the injectors from a 1zz 1.8L Colder plugs, premium fuel... And you should be good to go!! with maybe 125-130 whp and about a $1k or less spent... Oh... and in case we found an affordable way to tune fuel and timing on this car on the future... you will only need to turn the boost up!! as you ill be all set. Last edited by CASTREX; 03-29-2009 at 04:03 PM. |
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
i have a question!!!
say i installed a turbo kit into my yaris....... would i be able to have a on/off switch so that i can turn my turbo off when i dont need it so i can save fuel... and not damage my engine or anything like that?????????????
#9 | |
What you want to do is match the turbo size to your engine such that below 3200 rpms or so it doesn't spoolup, properly sized and with good tuning a turbo won't use much gas until you stomp on the accelerator. The issue with the Yaris is that a good tune looks impossible if you want to pass emmissions (OBDII). Even for off-road I don't know if there are standalone ECM that can handle the drive-by wire throttle. I think the Yaris is a few years away from daily driver type turbo set-up. Hopefully some hacker genius will get ahold of a Toyota diagnostics and reverse engineer the stock ECM. |
or, you can have some of the fancier boost controllers that give you 2 or more profiles. So you could have an "always open" profile that will not give you any boost whatsoever, and flick to the regular one when wanted.
Yes so far the only option that seems to work for US cars is a standalone ECU used in conjunction with the stock one (which handles the DBW, etc), or go nuts like Garm and convert the car to DBC
What's DBC ?
edit: Oh Drive by cable? |
thanks for your respones ....... plus the thing is my yaris is from australia so i dont think it is similar to US yaris..... and i am the biggest NOOB for anything about turbos !!!
I think I'm going to wait a few years before looking at boosting my Yaris, might look for an old Miata to restore and boost instead.
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
OFF 25% throttle 50% throttle 75% throttle I'm not trying to change your mind on the turbocharger, just wanted to set the story straight on the supercharger.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#15 |
yea i think i might go supercharger..... seems better option at the moment!!!
#16 | |
Also the reason i asked is because the K03 is tinyyyyy http://www.nogaroblue.com/turbo/TurboWheels.jpg (It's the S4 one) I am trying to find out what the wastegate is set at stock because i dont have a regulator on my air compressor to test its either 4 or 7 psi. I would be happy with 4 psi with new injectors and only a little lean, but i bet i am guaranteed a CEL which i do not want :( I'm going to try and sift through all of garms turbo threads, god help me |
#17 | |
I also got PO172 CEL's which meant I was running rich. This mostly happened when cold, decelerating or at idle. Pesky ECU !! -- but it's gone now..
#18 |
lol whats a little lean, thats what worries me.(I Tried to find your initial thread but everything is deleted from the hack!!) I'll be pushing a K03, at whatever the stock wastegate setting is non intercooled just for s's and giggles. Do you think I will get a CEL on that? I might just try to pickup a management unit before i even buy the mandrel bends...
| Turbo Questions | regal | Performance Modifications | 0 | 03-27-2009 02:07 PM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
| ZPI....I Have question's | punch | Forced Induction Forum | 15 | 07-02-2007 07:27 AM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
