Old 03-27-2009, 08:42 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
is the price on the site CAD or USD?
either way...cripes...looks good though.
I would hope it would come with some sort of bracket sometime...that silicone connector is going to fatigue no matter what and eventually give.
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-27-2009, 09:09 PM   #2
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
eh, it really depends on how far the filter construction goes into the connector and how heavy the filter portion is. the connector could also be quite rigid. it's hard to say what exactly will happen over time.
Wanted: Forced Induction
Old 03-27-2009, 09:27 PM   #3
The silicone connector is multi-layered and braided. It will take a long time for it to fatigue.
The entire unit is very light, and if you watch the video, I'd be more concerned about a mounting bracket causing the connector to pull away from the throttle body as the intakes movement would be restricted. Without a mounting bracket, the unit is allowed to move freely with the engine.
http://www.youtube.com/watch?v=kQofIM1wJI0
Old 03-27-2009, 11:18 PM   #4
Shroomster
Shroomster's Avatar
If you have a bracket mounted to the engine or trans (logically )
you wouldn't have to worry about the maf moving at all or fatigue at all;
but like I said fatigue will set in sooner than later because the silicone is what is holding the intake in the position it is in.
example I can think of is you're holding a balloon by the place you blow air into it. Your hand is the engine and the balloon is the intake....keep your hand still on a windy day and watch the balloon move around everywhere.
by the way I'm not opposed to the intake at all I'm just providing my constructive criticism and I'm not trying to be negative at all
(after all you can't 'read' text)
Old 03-28-2009, 12:17 AM   #5
dallas
Drives: Yaris Hatch /Landrover D2
I like the built in velocity stack to smooth incomming air.
dallas is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Bomz Ebay Intake - Partial Review Split Performance Modifications 11 11-19-2008 02:12 AM
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
Intake VS modified filter housing Spades Performance Modifications 19 03-30-2007 12:30 AM
