Old 03-27-2009, 09:37 PM   #1
RomGrr
RomGrr's Avatar
Drives: 2007 Yaris HB
Consider that the springs control the ride height. Therefore, with a shorter spring, the stock-sized strut will face a larger natural compression, even while parked. Less space between the wheel and the strut tower (which is the objective when lowering the car) means that the stock strut has to compress just to fit where it is supposed to. Shorter (and usually stiffer) struts do not have this problem because they were designed for lowered applications. There is no doubt that lowering springs place a higher burden on the stock struts. The stock struts WILL wear out faster because of this. Cutting the bumpstop is supposed to reduce the load placed on the stock strut by increasing the amount of room the strut has between the wheel and the bottom of the strut tower.
Make sense?
RomGrr is offline   Reply With Quote
Old 03-29-2009, 02:49 PM   #2
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
Make sense?
IN THEORY yes, but stock toyota is tokico rebadges i think. just like new 2009 rav4 sport has tokico blues on it from factory....
Old 03-29-2009, 05:13 PM   #3
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Someone had stock struts for sale the other day and said they were by KYB (had it stamped on the strut).
Old 03-29-2009, 10:02 PM   #4
Castaway
Drives: 2008 Yaris hb 2d
Make sense?
Hum, not sure... maybe i misunderstood the inner workings of the shocks...
About strut wear, i'll wait and see ;)
Castaway is offline   Reply With Quote
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
Yaris is low enough stock....trd springs bad??? Yawesh General Yaris / Vitz Discussion 13 12-26-2008 12:17 AM
Free for Local Pickup: Stock Springs, Shocks & Struts Violin Items for Sale by private party 4 11-14-2008 09:36 PM
using the tops from stock struts with new trd struts? tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-13-2007 11:58 AM
ordered my trd springs and trd struts earlier today tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-10-2007 06:36 AM
