Old 03-27-2009, 10:04 PM   #1
Originally Posted by 06vitzRS View Post
Does the rear wiper move the same speed or faster with the new stalk?
Same speed. The "high" mode is the normal speed. The "low" mode, if implemented with the Prius module, keeps it moving at the same speed, but adds a non-adjustable time delay between swipes.
Old 02-27-2013, 11:22 PM   #2
Kar98
Drives: 2011 Scion tC
I wouldn't mind that ;)
Old 02-28-2013, 06:39 AM   #3
You can have that with my intermittent rear wiper module. It takes advantage of the extra switch position, which is not implemented when you install a Prius wiper on a Yaris. I can build the module where the delay is adjustable (where it has a potentiometer that you mount to the dash) or where it is a fixed delay (where you simply bury the module under the dash and forget about it).
www.yarisworld.com/forums/showthread.php?t=43568
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
