Old 03-27-2009, 11:06 PM   #11
jkuchta
Drives: 2007 Yaris hatch (red)
The only experiance I have is with the Corolla TB, so that's the only one that I can say for sure fits.
Dallas,
The TB can't ice up, as there is no fuel passing through the TB. To get normal intake air to ice up you'd need to run it through a really small venturi to get the pressure low enough.
Hatchbackkid, do you know what the DTC associated with the CEL is? Sounds like you have an air leak. Don't forget that the silicone sealent has to sit for a few hours to harden enough to resist the vacuum at idle.
jkuchta is offline   Reply With Quote
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
