#1 | |
Mr. Clean
http://store.summitracing.com/partde...5&autoview=sku It increases voltage to the fuel pump as boost increases. Seems like it could be a good solution for moderate boost levels. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Any mechanical engineers out there?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Ive seen the Boost-a-pump used on a buddys Mustang and it works well, if you need to squeeze a bit more out of the fuel pump. If Richard Holdners Intake /exhaust combo made more hp than the supercharger it must be using more fuel to acheive this. I don't think it's the fuel delivery, but maybe the management of the delivery thats causing a lean condition. I wish you pioneers luck to figure this out.
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
