Old 03-28-2009, 08:40 PM   #1
Uncle Yaris
Drives: 2008 Yaris 5-door
Originally Posted by goku87 View Post
Does it really matter which terminal you disconnect whenever you are installing stuff? I've always disconnected the + but only recently for some reason I keep noticing everywhere that you should disconnect the -? Does it really matter?
Yes, it matters. If you disconnect the positive and accidentally short the wrench to ground, it can cause a fire or even an explosion (hydrogen gas in the battery - remember the Hindenburg?)
If you disconnect the negative, shorting to ground with the wrench won't do anything, since it's already connected to ground.
Uncle Yaris is offline   Reply With Quote
Old 03-28-2009, 08:44 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
agreed, however this would only be if you touched the pos+ on the battery to a ground point on the car, regardless, good practice is to disconnect the neg-
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Which of These Car Companies Will Go Bust First? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 11-16-2008 10:50 PM
