![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I have not heard audible evidence of knocking like I did before I filled up with 91 octane. The only reason that I am guessing there is knocking is the ingition timing being retarded. I know others have to add octane boosters to stop their audible knocking.
I'll reset the ECU on Sunday and try the tests suggested.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#2 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
#3 | ||
Anyway, looking at the new data Pavel logged, it looks like there is a correlation between throttle % and closed loop mode. It was a pretty short run but it looks like above 75% throttle, the system switches to open loop. So, perhaps the blitz unit is reporting 100% throttle to the ECU no matter what, once it kicks in the SC? Now this is something that Long can check with the scangauge, see what is the reported throttle angle once the SC kicks in... If it jumps from actual throttle position (say 50%) to a much higher value, then bingo, we know how to trigger open loop safely
#4 | |
Break'em off some.
There is more than one metric that triggers open loop. Generally speaking there is RPM, Load, and TPS. Depending on the ECU, the car could be using one or all 3 as reference points. |
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
