#1 | |
On the other hand, it is something I am not so sure about in the first place, at three quarters throttle, 4000RPM, for example, is there enough pressure from a SC/turbo that it would require fuel enrichment? Or am I barking up the wrong tree?
#2 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
You are thinking correctly. Generally forced induction cars go into open loop sooner than NA cars. Some NA cars don't hit open loop until you go WOT. My guess is that this is one reason the Blitz SC is clutch driven, so you are not getting boost at lower load areas. We can't see the actual AFR, but we can see his timing, which will be helpful. Can he graph injector latency or duty cycle too? If so get that on there. You can't hope to tune closed loop, no piggyback I have ever seen can do it. It just causes problems. |
#3 | |
Break'em off some.
Your list for that other pull had all the stuff we need, except for injector duty cycle or pulse width. |
