Old 03-31-2009, 02:26 PM   #1
supmet
Drives: 2007 4 Door Yaris
hmmmmm you also need to have a pole dancing barbie doll on there somehow
but yeah I agree with PK, some kind of a flat board against the headliner might be a good idea...
I'll bet if you did that, and stuck a little piece of rubber or memory foam in between the boards and the floor/ceiling, it would help stabalize the shot a tiny bit.
Old 03-31-2009, 03:12 PM   #2
mike a little suggestion make the ends on the top of the rods larger , you will reduce the print on the roof trim and make it more stable. gret job BTW very clever.
Thanks guys, I'll keep that in mind. No vibrations at this time and it's pretty solid as I can control the tension and stiffness by twisting the rods. I found out quickly that the headliner has about a 1 inch play area between the roof and the liner. I'll get that video situation worked out soon. Long had a chance to see the video so he can give you a first hand review of the it until then. Thanks again for the kind words and suggestions.
