Old 04-01-2009, 09:30 AM   #1
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
Originally Posted by AlanSRT4 View Post
No that is not normal you need to take it back to the dealer mine did that since new and untill I made them go over it they did not do anything. I then showed where the car if you rev match is supposed to shift into first gear at 15mph and below. They ended up having to do almost $2600 of work under warrenty on the transmission.
to the part about it not being normal...not the work they may have done.
See Loren's post.
You said you want to shift into first and hold the clutch in so you can start going again faster....... just keep it in second, or be patient for 1-2 more seconds and slow down more before going into 1st. To avoid some of the wear of jamming it into 1st, try a SSK kit, which will make the shift harder (more effort on your arm, less on the synchs)
Otherwise, (and I hate to have to be a smart ass here) but if you want instant response at any speed, consider trading for an automatic transmission.
His grace is sufficient.
SeaYa is offline   Reply With Quote
Old 04-02-2009, 02:33 AM   #2
tomato
tomato's Avatar
now THAT's total
MT are far more responsive generally than auto. The Yaris's clutch is just weird.
Thanks indeed, Loren, for the explanation and link.
Old 04-02-2009, 08:45 AM   #3
SeaYa
SeaYa's Avatar
Drives: 08 MT Sedan
now THAT's total
Yah, it is. Instead of referring to throttle response, I should have said...get the engine to respond without having to do any work other than push your foot down.
Way to keep me honest to the adage...."Mean what you say and say what you mean."
Tags
transmission weird manual
Manual Transmission...Safety Issue!!! twocvforme General Yaris / Vitz Discussion 189 10-30-2010 11:00 PM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
Manual Transmission woes thatboyjer General Yaris / Vitz Discussion 24 07-30-2007 07:46 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
JDM Center Console Box + Manual Transmission bigsky2 Cosmetic Modifications (Exterior/Interior) 5 11-28-2006 08:08 AM
