Old 04-03-2009, 05:53 PM   #1
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
Originally Posted by changchewsoon View Post
I'm currently using the MAP sensor purchased from Trust Japan, JDM Vios does not come with a MAP sensor from the factory.
The MAF signal can be clamped via the E-Manage tuning software, its a standard feature that comes with E-Manage.
With an E-Manage Ultimate, you could even clamp the stock narrowband O2 voltage.
where does the emanage ultimate clamp O2? I'm looking at all the wires but none of them intercept the O2 signals.
taKuto is offline   Reply With Quote
Old 04-04-2009, 04:23 AM   #2
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
You need to look up the wiring diagrams, E-Manage Ultimate has an auto tune feature which you set in a AF ratio and E-Manage will try to adjust itself to dial in the AF ratio set by you.
It works by blocking the stock O2 which is narrow band and sends an adjustable lean signal to the stock ECU to keep it from pulling fuel
in a closed loop operation.
You would need to have a wideband O2 sensor installed to use the E-Manage Autotune feature.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-04-2009, 12:43 PM   #3
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
I'm currently wiring up an emanage ultimate and nowhere in the installation manual does it have any wires related to the O2. I understand the need for the wideband plugged into the serial input, but the O2 is still not handled by the emanage itself.
All i've been reading on the internet is that people are making/buying an o2 clamp. I'd imagine it's just a comparator or something feeding the lean voltage to the o2 once you're in boost, shouldn't be too hard to figure out how to make one.
Old 04-05-2009, 07:55 AM   #4
changchewsoon
Drives: Vios Turbo
Dear Takuto,
Apologize for the confusion, a wideband O2 is exactly what I was trying to say regarding the wiring of E-Manage Ultimate which is for the autotune feature. An O2 clamp/simulator is mandatory, I missed out the wideband O2 simulator I'm using.
in a closed loop operation. <----My LM-2 does the job.
For the narrowband O2, like you said you could either clamp it or use a simulator. Personally, I think using a simulator is better as you could tune narrowband rather then clamping it at a fixed voltage.
Turbo Questions regal Performance Modifications 0 03-27-2009 02:07 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
ZPI....I Have question's punch Forced Induction Forum 15 07-02-2007 07:27 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
