Old 04-04-2009, 01:26 PM   #1
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
what is an actuator? is it aftermarket power locks?
Syroyizhka is offline   Reply With Quote
Old 04-04-2009, 06:23 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
its basically a little piston that can push/pull and object. Generally you have to use two relays with them to make them work... You hit the button and 1 relay engages and you get a push... Hit the button a 2nd time and the other relay engages and you get a pull....and so on.
they are used for all sorts of things, auto locks being the most common, but also on stereo installs for amp racks.
hatchback trunk power
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 04:14 PM
Power Lock button?? cyberfrogg DIY / Maintenance / Service 25 03-26-2009 10:16 PM
Power hatch lock? paultyler_82 DIY / Maintenance / Service 5 09-08-2006 01:15 AM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 01:18 PM
