Old 04-05-2009, 09:29 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
Well if you look one spark plug cost 5.95 and another spark plug cost 20-28 dollars depending where you purchase them there has to be a difference. One is designed by a oe manufacture for ford and one is a oe manufacture for toyota. Me personally i would rather get the part from toyota. From my experience autolite starters, and autolight altenators and batterys are pieces of junk. My friend works at kragens and he says he gets a rediculiouse amount of warrenty returns on them. So i would not use a spark plug made by that particular brand in my vehicle. Either denso or ngk is all i would use. All we know is many users have had no problems with coil failures and users that have had coil failures reported using a alternative plug. Search all the posts for coil failures you will find what i am saying has some sense to it. I remember last month if orget the brand but it was suposily some high performance plug some user had problems with failed coil as well.
From my own personally experience the only coils i have changed on cars when i removed the plug it was either extremely worn out or a different type of plug.
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
FS: OEM NGK Spark Plugs mikenacarato Items for Sale by private party 13 01-23-2009 05:05 PM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 09:38 PM
