try to let the key to "on", until everything has settled down before cranking it.
i've had this issue once... I've always turned the key straight to START each time and let the computer do its job to crank it until it starts. It did it 2 days straight.. slow to crank and felt like the battery was about to give up. I've not had this problem since. |
#2 | |
![]() Drives: 2007 Black LB Join Date: Nov 2008
Will make an effort to see if that may be it. Thanks to All for some good ideas.
#3 | |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
Make sure you fasten your seat belt before you start your car also, that beep sound seems like causing a little drain for the battery to work.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Lightweight battery install | Klink10 | DIY / Maintenance / Service | 11 | 02-28-2009 08:43 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
