Old 04-06-2009, 11:09 PM   #1
PolarWhite
PolarWhite's Avatar
Drives: '07 Polar White Hatchback
There is no harm in using any name brand fuel additive. I can also tell you that it doesn't matter what brand of fuel you are using, they don't have enough fuel additives in them. I worked for Texaco for years. They would pour a measely 5 gallons of fuel additive in an entire tanker truck of fuel. Hardly enough to do a good job of cleaning your fuel system. Valvoline is one company that makes a complete fuel system for use beginning when a car is new all through its life. You use a pour in at 3k, 6k and 9k and then a little stronger one every 12k. Start over again and at 36k, you have the injectors cleaned with a 3-part fuel system. The idea that people pour an additive in their gas and increase their mileage by 5mpg or more is ludicrous. They are meant to keep the fuel system from getting dirty in the first place.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads,
PolarWhite is offline   Reply With Quote
Old 04-06-2009, 11:31 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Well to be raited top tier you are required to have a extensive amount of fuel addatives. I dont think texaco is on the top tier list.
In northern california i know the main ones are chevron ie techron, shell ie v-power and then 76 i forget thier fancy name for thier addative.
But if you are running any of those top tier fuels you will never have buildup on top of pistons or valves. I know because i ran seafoam through a vehicle that had over 140k miles and the owner has always used chevron gas. There was no smoke or funny smell comming out of the exhaust when the service was done. Engine was spotless.
And i performed the same fuel system cleaning on a vehicle with 30k miles who used only discount gas, IE rotton robbie, BP, Arco, Costco etc. And that thing smoked for atlesat 30 minutes. THe cloud of smoke went from out the shop into the street and nearly caused a traffic accident as it was extremely thick and dense. Also the smoke completeld filled up the shop and went into the office area choking the customers. The owner who was waiting came out to see what was going on to find out it was his vehicle. He swore never to use cheap gas again. To those reading this may think its a exaggerated story but it is completely true.
He swore never to use cheap gas again. After the service was done he commented on how much better his vehicle ran and idled and brought his wifes car in for the same service as well.
Since then ive always used chevron personally because of my own personal experience seeing the effects.
Old 04-07-2009, 04:38 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The corner gas station gets his gas from the same place the big name gas stations get their gas,not like Joe's discount gas has his own refinery.Up here in Canada gas is strictly regulated so theres no such thing as top tier gas as it all has to conform to government standards.Additives? each my last 6 vehicles have gone well over 200k with regular gas and no additives added by me just regular maintenance and i have had no engine problems,no burning oil,no sludge build up.So if you want to spend your money on additives go ahead its good for the economy,whether it does anything for your car
Hang Time: Exploiting ECU Fuel Maps for Fuel Efficiency BailOut Fuel Economy Forum 20 11-13-2013 08:11 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Yaris Fuel Cutoff Switch Possible? Disturb3dMind3d General Yaris / Vitz Discussion 1 06-12-2007 05:32 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
