Old 04-07-2009, 07:22 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
you probably fried the internal amp.
although.. you might want to check the fuses... i'm almost sure there's an internal fuse on the HU itself.
Old 04-07-2009, 07:34 PM   #2
dccurrent
Drives: Yaris 5 door Liftback
Would the fuse be behind the head unit or literally inside it? This is so aggravating and I am so upset at myself.
dccurrent is offline   Reply With Quote
Old 04-07-2009, 10:20 PM   #3
dccurrent
If the internal amp is indeed fried, would I still be able to use the preamp outputs to install an external amp? Is there any way to check these connections?
