Old 04-03-2009, 02:40 PM   #1
camelll
Drives: 07 sedan
camelll is offline   Reply With Quote
Old 04-03-2009, 02:48 PM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Mike,
Compare your plugs to this pdf file from Bosch.
Old 04-03-2009, 03:03 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yes that color is from the additive. The plugs look ok. Are those the stock plugs?
Why are you running additive? If it is to reduce knock, stop running additive and run plugs one heat range colder.
Maybe you have a vacuum leak somewhere.
Old 04-03-2009, 03:09 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It's just my opinion. The plugs look oily on the threads. It also looks like it's not burning cleanly. I have no experience with supercharged engines.
Old 04-03-2009, 03:56 PM   #5
largeorangefont
Break'em off some.
Originally Posted by camelll View Post
Yeah I thought the plugs looked good too, I was just curious about the color, never seen it before. Yes I am running lucas octane booster to stop the pre-ignition. Those are not the stock plugs they are ngk iridium ix 7 heat range. 2 ranges colder than stock. I am pretty sure put not positive that I don't have a vacuum leak but the car runs top notch while driving and under boost. I did not have this problem until I changed the air filter and emptied the oil catch can but this is the first time this year I tried the ac. So the only things that have changed is adding the lucas octane booster, changing the cai filter and emptying the oil catch can. The only hoses that were disconnected were the one going to and one going from the catch can. Again I am almost certain I don't have a leak. I am leaning towards the octane booster, bad 02 sensor, catalytic converter or bad maf but shit if I know what the problem is. LOL
Cean your MAF and reset your ECU and see if it keeps doing it. Do you use a oiled air filter?
Old 04-06-2009, 12:13 PM   #6
Hmm curious... I am looking through the repair manual to see what they say about this particular code, "system too lean", and quite a variety of common causes...
Like you said it only really happens at idle, so my gut feeling is it has something to do with your PCV hoses. I know you are 99% sure that's not it, but that's still a 1% chance that it might be I mean, idle is when you have the strongest vacuum in the manifold, correct? so if there's a leak somewhere, it would thus probably have the biggest effect in this condition, and not while the throttle is opened wider.
And, Occam's razor... You messed with the oil catch tank, a problem happened, always look for the simplest explanation first
Old 04-07-2009, 11:32 AM   #7
kurokoma-kun
Drives: 2007 Yaris HB
Only at idle, when the engine rpms go up and then when they go down (to about 600 rpm) is when I get the code, I confirm this with my wideband so I know I am seeing the condition.
I have had a similar wanting-to-stall/idle hunting issue (though no DTCs set) three times now: the first time right after installation, the second time after messing with the alternator connection, and the third time very recently, for no obvious reason.
The second time I had to disconnect the lower radiator hose and dropped some coolant. After adding coolant I "burped" the air from the lines... I had to repeat this twice, after which the idle hunting went away.
This most recent time I found my coolant reservoir cap slightly open and the tank nearly empty. After topping off the radiator and filling the reservoir half full, all seems well again. Not a "by the book" solution, just my experience, and easy to try.
I also tend to get low idle speed and fluctuating ignition timing, etc, every time after disconnecting the battery/resetting ECM. It just seems to take a few normal driving sessions for the system to settle.
Old 04-07-2009, 11:43 AM   #8
kurokoma-kun
I am gonna bypass the catch can and see if one of the lines is the problem. I did notice today that my vacuum line coming from the catch can going to the intake is sucking in. I know the car is in vacuum so I would expect this a little bit but the whole hose damn near sucks in. Like the hose is weak or something is plugged.
Did you replace the hoses that come with the catch tank kit with real heater hose? The one supplied with my kit is just plain weak I replaced the outflow portion and plan to replace the other as well.
Old 04-07-2009, 11:56 AM   #9
kurokoma-kun
The car runs great while normal driving and during boosting, just at idle and it is not all the time. Only every once in awhile.
Annoying, isn't it?
Just FYI, I bought 11/32" heater hose plus a scrap of 19mm for where it hooks up to intake manifold
Old 04-07-2009, 12:03 PM   #10
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
This is all good to know. I'll definitely be getting a catch can at some point soon.
2006 Red Blitzed RS 5-door
Old 04-08-2009, 10:21 AM   #11
kurokoma-kun
Sorry for the thread jack cammelll, I'm just grateful to you for providing the nudge to get my catch tank!
Doc, if you buy one I totally recommend getting decent heater hose and trashing that shitty clear stuff that seems to come with most kits. I installed mine on Saturday, using one piece of good hose... car seemed ok at first but ran like crap yesterday, the piece of clear hose was all sucked in--replaced it last night and now it runs like a champ!
Why do companies do this, make it harder on customers to save a few cents on a length of hose?! grarrr
Old 04-08-2009, 10:33 AM   #12
LtNoogie
LtNoogie's Avatar
My catch can just arrived at my P.O. center. I'll install it this weekend.
Old 04-08-2009, 12:28 PM   #13
YarisSedan
Drives: 08 Yaris Sedan
Ive always had a slightly lean condition since i installed my weapon r intake. Because of the relocation of the MAf sensor closer to the throttle body. So much that the fuel trim was starting to max out.
Old 04-08-2009, 12:29 PM   #14
kurokoma-kun
Well I just put the factory hose on and bypassed the catch can and I am still getting the lean condition. I am in the process of pulling the MAF again and try cleaning that one more time. If that don't work then the next time I get the oil changed and I will have them replace the pcv valve and then if that don't work then the only thing left to do is to start replacing 02 sensors which is probably gonna be expensive. What else can it be?
Well, based on the DTC seems about all it can be is the MAF, an air induction leak after the maf, faulty/clogged injector, ECT (coolant temp) or AF sensor issue, PCV problem, fuel pressure loss... EFI relay in fuse box is another one, seems unlikely?
I think the reason dealing with the air in the coolant lines solved my idle control problem is because the ECT is one of the things that tells the ECM to enrich fuel mixture after warmup. An air bubble screws with sensor reading and trouble is intermittant. I'm guessing my low coolant level also caused the similar problem later.
Another thought, before you go replacing sensors willy nilly, do you have any way to check their function first? Of course the dealer uses the "intelligent tester" thing, but I don't remember if Autozone or other places can also test such stuff for you
Old 04-08-2009, 04:36 PM   #15
kurokoma-kun
I don't know how toyota checks those...
I think they basically do what you did, except they spit on the finger before running it around inside the intake
dayam, $600 I hope it doesn't come to that. Dunno maybe you need some more good luck charms... anyway, you'll figger it
Old 04-08-2009, 05:35 PM   #16
kurokoma-kun
well hot diggity dawg! good news at last
how the hell did you get a clamp on it down there? did you have to remove the TB? or do you mean you clamped the top end
Old 04-08-2009, 09:51 PM   #17
LtNoogie
LtNoogie's Avatar
You should sell your boost gauge to KK and buy a vacuum/boost gauge like I have. You would have seen that your vacuum was off.
Old 04-08-2009, 10:43 PM   #18
kurokoma-kun
I have a boost/vacuum gauge. The vacuum was not out of the ordinary, that is why I was so stumped.
lol, I got a boost/vac gauge from Garm ages ago Noogs, autometer ES series (same as yours?) looks like most of us went with autometer come install it for me why doncha, take your mind off your fuel injected fever dreams
congrats on tracking down that slight hissing camelll! it's interesting because I examined that same hose on my car tonight and found the stock tension clip dealie not tight at all... is it better to use the screw type clamps on vacuum hose?
