S/C owners: collecting information
Blitz needs to know a few things to help us out with the issues some supercharger owner are experiencing. There seem to be a few issues -- overboosting, lean condition and knocking/pinging.
Please describe your symptoms (and please post with information about your set up and mods if you are NOT experiencing any problems). We are working to have them provide several fuel maps to test out. I will require a local test car, and this may involve some dyno pulls, but there will be no expense to the owner. Boost Pressure Issue 1: Boost Pressure you have reported was over 7psi, does the pressure stay at 7psi consistent or go up and down ? Knocking Issue A: What Gas octane are Supercharger customers using ? B: Does knocking occur using Stock Air Box or aftermarket Air intake system? Does it occur with one octane but not with a higher octane? Please describe. C. Please list any other engine modifications besides the Blitz system. ok - thanks guys, we will continue to try to facilitate a solution for you.
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
My other mods are AEM cai, DC sports header, Nitto midpipe, Tanabe concept g exhaust, NST lite crank pulley, NGK 7 heat range spark plugs Thank you Garm! Sorry I can't help with the AFR and boost pressures (still no gauges ). Like Yaris Tsport I am still thrilled with the overall results, worth every bit of effort
Mods: aFe Intake, NST crank/WT/ALT pulleys, NGK spark plugs, Megan header, 2.25" mandrel bent exhaust from the header back, hi flow cat, 18" resonator, 2.25"dynomax super turbo muffler
No knocking/pinging/pre-ignition. I use shell and 76's 92 octane. I also add lucas oil octane booster from day one. My A/F readings from the dyno showed that I ran lean. I don't have a boost gauge to read my boost, nor a wideband to show a/f. *I will be going to the dyno tomorrow (dynojet), and hopefully get some pulls in. I have a scangauge now so I will show my a/f readings with ignition timing and hopefully they can hook up a line to my boost/vacuum nipple while on the dyno to show the boost. ps: thanks garm for taking the time to work with blitz on figuiring this out! Last edited by PETERPOOP; 04-07-2009 at 09:46 PM. |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
My engine mods: aFe intake Blitz S/C Megan 4-1 header TRD exhaust NST Pulley Set 1. Boost pressure max's out at about 7 psi. I run the same Autometer AFR gauge that Camelll uses. A. Shell V-Power 91 Octane. No pre-ignition. No octane booster used B. n/a C. aFe intake, Blitz S/C, Megan 4-1 header, TRD exhaust, NST Pulley Set, NGK Iridium heat range 7 spark plugs, MicroImage sticker AFR measures 14.7 to 14.9 at WOT with boost.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Great thread
Can anyone besides Camelll confirm overboosting?
#7 | |
I would suggest those who experience pinging try a top engine cleaner such as seafoam through the intake manifold to remove all carbon buildup on the valves and on top of pistons. And then see if the engine still pings. Chances are it will make it better if not remove the pinging all together. Just a thought. |
#8 | |
aka SDMF
mods: fujita cai, tanabe touring medallion exhaust, nst pulley set, ngk bk7 plugs, perrin oil catch can if that matters.
been running bp or shell 91 octane since i got the sc. i dont know if you would call it a knocking but when i gun it in 2nd after i hit 50 it feels like it studders so i shift into 3rd, that just started lately so i shift, i dont have any other gauge to test whats goes on during that period, will try that octane booster and see if that goes away, i love the sc and enjoy it on the highway when i can. |
Shouldn't be.
Ok, I got good news and I got bad news. I went to the dyno jet today and I made the most WHP any blitz owner has made so far. 133.06whp and 133.22 torque. However, I have the highest A/F readings than anyone too! haha. I dont know why I am laughing. This actually is pretty lame. They only did one pull and saw my crazy AFR and refused to do anymore. Everyone gathered at the dyno place and was outraged by the AFR. They couldn't believe blitz would sell a kit that put down 18-19 af readings. They were also surprised that is was not misfiring. I was rated at 8 pounds of boost during my pull. I am pretty mad at blitz right now.
ps: I could have probably made higher HP numbers if I did my other two runs! ;) I really hope blitz can put a stop to this... Here is my dyno chart from today... ![]() Here is my old AFR dyno reading from a DynaPack dyno. ![]() Only different thing that I did between my two seperate dyno runs were I put a hi flow cat on a changed my muffler. |
+1. Pretty weird to be that different from one place to the next. How were they reading A/F exactly?
I'm willing to bet that Blitz designed this kit to be bolted onto a STOCK yaris, especially the airbox. Is ANYONE running this kit on an otherwise stock Yaris? If you add a bolt-on boost kit to an already modified car, you might not be using it as intended. Nice of Blitz to take a look at your modified setups and try to help out.
#13 | ||
However, like you said, my car IS running fine. No misfiring (like the dyno tech would thought be happening) and everything seems normal. If it wasn't for the dyno, I would be oblivious to all of this. For now, to be safe, I am going to be running with the compressor set to "off." I am REALLLLLLLLYYY hoping blitz can make a new fuel map to take into consideration all of the other aftermarket mods MOST blitz owners have installed in their car already. If they do make a new fuel controller and that doesn't fix it. I am going to have to throw down some $$$ to have someone tune this thing. I talked to a tuner at that shop and he is supposedly one of hawaii's best. He said he is confident he could tune it if we got rid of the fuel controller and used either the AEM FIC, Greddy Ultimate, or the F-Con (sp?). But he said that would cost me. Not too excited about that idea I hope blitz can pull through for us! ![]() Quote:
They hooked up a sensor to the end of my tailpipe while I was at the dynapack AND dynojet. |
Vroom Vroom Beep Beep
I know this is for blitz owner but I am starting to wonder if Blitz did any R&D on their piggy back for the US yaris or if they just included a xB or Japanese yaris piggyback in the kit.
Ever blown out an R-200 diff god know's I have
Peter, you need an A/F gauge. If you're measuring 18-19 regularly under boost, soon, one of your videos will sound like...VROOOOMM POP! putt putt putt pffffffff.
haha, I know I need a A/F gauge ASAP. but no vrooom pop putt putt here. Compressor will be set to "off" until everything is figuired out. Until then, the number "133" is my new favorite number! ;)
Those numbers are more in line with what I expected. Get a vacuum/boost gauge while you are at it.
I used to have 1700 posts
Mods- AEM Cold Air Intake, NST Light Weight Pulleys (set), 1ZZ Throttle Body w/Spacer, Weapon R Header, Nitto Midpipe, Tanabe Medallion Touring Axel Back Exhaust
I use 93 Premium Octane from whichever gas station i am closest to when i run out. and Autolite spark plugs that are 2 steps colder than stock. i havent had any dyno pulls yet but my wideband a/f ratio gauge shows normal readings around 12 at WOT. boost reading show anywhere from 7 to 9 pounds of boost WHEN I TOOK MY PVC HOSE OFF THE INTAKE MANIFOLD IT WAS DUMPING WAY TOO MUCH OIL INTO THE MANIFOLD. going to invest in an oil catch can very soon |
| i have a q to US owners | FlyingDevil | New YARIS Purchase Forum | 33 | 03-26-2009 10:20 PM |
| Yaris owners in Edmonton,AB | 06vitzRS | Canada | 6 | 02-20-2009 08:38 PM |
| Doctors Vs Gun Owners | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 01-29-2009 08:36 AM |
| READ YOUR OWNERS MANUAL!! | MadMax | General Yaris / Vitz Discussion | 29 | 12-14-2008 11:38 PM |
