Old 04-11-2009, 06:18 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Originally Posted by wiirenet View Post
This prob sounds dumb, but the head rests bothers me a lot too. I don't know if its just taller or wider than my old car, but I feel like that is my biggest vision issue, not the pillar area in the back between windows. I can't crank my head around it I guess, I don't know.
The driver's headrest gets in your way or the passenger's headrest?
Old 04-24-2016, 07:04 PM   #2
bairjo
It's true, the Yaris does have a lot of blind spots...
bairjo is offline   Reply With Quote
Old 04-10-2009, 05:28 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I don't have problems with the rear head rests in my sedan. they can slide all the way down pretty well.
I find the rear view mirror hiding cars on my right when crossing + intersections.
I also find the driver side's A pillar hiding my lines when turning left.
Old 04-13-2009, 01:40 PM   #4
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
The driver's head rest. Its all the way down, but when I do a head check behind me I really need to crane my neck to see behind it. I know I should just use my mirrors for this, but I've just gotten used to double checking everything by turning my head.
wiirenet is offline   Reply With Quote
Old 08-02-2013, 08:43 PM   #5
gollygirl1
gollygirl1's Avatar
Drives: YR Yaris 2013
Well this is something my driving instructor taught me to do anyway, check mirrors and then a quick check over your shoulder in the blind spot - makes good driving practice
I was watching a video on You Tube though the week that shows how you should set up your side mirrors - in the old days you set the side mirrors up so you could see along the side of your car as well, but now things have changed - it was interesting and I learnt a lot (good old You Tube).
Also how the old placement of your hands at the 10 and 2 position (as in the face clock) is now "old news" - the 9 to 3 position seems to be considered best - why? Because if an air bag goes off your hands will hit your face at the 10 & 2 position, but if you have them at the 9 & 3 position they hit the sides and deflect away from the face.
So things change a bit as technology improves.
I do admit the headrest takes some getting used too, in the first three weeks I have had my seat up and down, back and forward etc - and finally have a comfortable position. I found also the brake higher than my old car and more sudden too, so it just takes time to get used to all these things. I think a month and you are finally all relaxed.
gollygirl1 is offline   Reply With Quote
Old 08-02-2013, 05:09 PM   #6
Dariuus
Drives: Electric Blue Yaris 5 door
Rear view blind spot
My rear view mirror creates a blind spot to the front right. This week it caught up with me. I did not see a vehicle at a 4 way stop. I ended up running into it and totaling my Yaris. Personally I am done with Toyota. All it would have taken is a joint to raise the mirror so tall people could see without interference.
Dariuus is offline   Reply With Quote
Old 08-02-2013, 07:03 PM   #7
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
Is this the only issue you've had in the 5 years & 10 months since your first post?
yougojay is offline   Reply With Quote
Old 08-02-2013, 08:42 PM   #8
edmscan
edmscan's Avatar
Drives: 2020 Corolla
There is something called a "shoulder check" ... along with Daytime Running Lights, they work well to prevent collisions.
edmscan is offline   Reply With Quote
Old 08-02-2013, 08:47 PM   #9
gollygirl1
gollygirl1's Avatar
Actually, I have a slight issue with the mirror too - lucky for me I am short so it is not a vision out the windscreen issue - but in the mornings when driving to work - sometimes the sun shines between that gap between the top of the windscreen and the mirror - I do wish it was just a little bit higher - but then I guess I might not be able to see out the back window - which would defeat the purpose - but compared to my old car, the mirror does seem a couple of cms lower I think? But I just duck a little bit to compensate.
Old 08-02-2013, 11:14 PM   #10
matti
Drives: 2017 Yaris L (5sp manual)
I'm a bit tall (6'4") and I have a solid blind spot to my front right as well. I know it's there, however, so I'm extra vigilant when looking that way.
matti is offline   Reply With Quote
Old 08-03-2013, 02:23 PM   #11
nookandcrannycar
^^^^^ This. I'm a fraction of an inch shorter than you, but I 'sit tall' (longer torso) than most people my height. I also took all of the head rests out of my Yaris when it was new. I always put one back in (at her mom's request ) when I drive my little cousin somewhere.
Old 04-24-2016, 01:49 PM   #12
cparker
Drives: 2014 Yaris L
Yes, the outside rear view mirrors are small and triangular, probably for aerodynamics . I would like to see bigger square mirrors, and I wonder if there are any other Toyota mirrors that would fit. I stuck on some small round convex mirrors to increase visibility. I also stuck a wide angle plastic lens on my rear window. See the backup camera thread.
cparker is offline   Reply With Quote
Old 04-24-2016, 08:56 PM   #13
tmontague
tmontague's Avatar
Set your mirrors up properly an you'll reduce them by about 90%.
Set you drivers side mirror up so you can just see your rear door handle with your head touching the drivers window.
Set your passenger side mirror up so that you can barely see the rear door handle when your head is moved the the middle of the car (over the console)
It feels weird at first but it has saved my ass countless times when making a lane change. I found this tip in a men's health magazine years ago. I will never go back to my old way.
Old 04-24-2016, 11:45 PM   #14
CoryM
Drives: 2009 5-door, 5-speed
Except for the A-pillars, the Yaris seems good to me. The mirrors are good and there is no reason to have rear blindspots. It did take a while to get used to the A-pillars as they can hide pedestrians at opposite corner of the intersection. Now I lean forward a little to make sure it's clear. Only other surprise was the mirrors do not show 2lanes over as well as you would expect (think merging onto freeway and looking at fast lane). Every car has more or less visibility in certain areas, and it's just getting used to it to make sure you see what you need to.
Old 04-25-2016, 12:37 AM   #15
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I find many other drivers have a "Blind Spot" that specifically prevents them seeing an approaching Yaris when they want to pull out from the kerb. This blind spot occurs even if I have the headlights on in the Yaris.
The people with this blind spot also seem to be incapable of driving at any speed more that half the posted speed limit.
Old 04-27-2016, 01:42 PM   #16
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
I must say, that I do think my 3-door hatch is very hard to see out of, especially in the rear quarter area because of the thick 'c' pillars. Coming from a Festiva with those impossibly thin pillars and low belt line to the Yaris was a challenge at first. Unfortunately thin pillars are probably never coming back.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 04-27-2016, 04:26 PM   #17
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
I had a 91 Festiva L that I bought used in 92 for $4500 from an Air Force guy that was being moved overseas. I miss that car terribly. I should have never sold it but I was young and dumb around the age of 24. I was given a Maxima and didn't have room for 2 cars in DC. Those cars were indestructible. Still see them on the roads today. Mazda engineering and put together in S Korea by a little known company at the time-Kia. Kia even sold the Festiva badged as a Kia. I believe it was a 121 that Mazda had sold in Japan. The heat wasn't that great in our extremely frigid winters, and it didn't have air conditioning, but I wasn't going to pay $10k for a new Tercel that my dad was pushing on me. He was good enough to cosign, but I paid the car off in full, my own insurance, gas, clothes, and even food. My dad was a tough rancher who believed in his kids succeeding on their own. I worked so much in high school that I had no free time or even time to attend the prom. Oh well. He was right. If I had kids I wouldn't be nearly as tough, but they would earn their keep like I did. The Festiva was a car me and my dad bonded over. It was a manual. He taught me to drive a manual and actually drive in his 1980 Bronco. Good memories. What made you decide to let go of the Festiva?
BLKHILLSGUY is offline   Reply With Quote
Old 04-27-2016, 05:14 PM   #18
Deathegg
Deathegg's Avatar
Rust and high cost of some repairs. Bought it NEW in '88. When I finally sold it, it had 235k and was 23 years old. Spent most of it's life in Pittsburgh, so the salt on the roads got to it. Bad frame rails, engine mounts, brake lines, gas tank leaks, etc, etc. Sold it because it needed an alternator, and I didn't want to spend $200 fixing this $300 car anymore.
But yes, the Festy's are greatly unappreciated, and tough as nails. Engine was never apart, and had the original clutch when I sold it. Here in SoCal I've seen them around with no rust; love to get my hands on another one. (Actually, my name here on YW was the name of my Festy, DeathEgg).
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
Blind Spot Spot Yar Is Word Cosmetic Modifications (Exterior/Interior) 17 07-03-2009 06:23 PM
Water Spots RogueYaris Wash, Wax, Detailing, Exterior Repairs 23 05-09-2009 11:42 PM
Probably a dumb question - Flat spots 33OH Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-22-2008 01:41 PM
Racing Spots blake111887 NY / NJ/ CT / PA 10 05-17-2007 08:07 PM
