Old 04-10-2009, 11:53 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Here is a crazy idea - I was always thinking about trying to mount a shock (bike/motorcycle) somewhere on the top/side of the engine. If I remember correctly there are a couple of threaded holes on the bottom of the engine which have no screws and they are pretty good size. How about a piece of curved spring steel such as a leaf spring? It has just a little give. The point where it is mounted to the body or frame, a series of dampening washers could be used to cut down on vibration. They also usually have one side where a bolt can be used to mount it.
What do you guys think?? Easy, cheap and probably very effective.
fuji is offline   Reply With Quote
Old 04-10-2009, 11:58 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
You guys are crazy. Just buy the nitto. ;)
Old 04-10-2009, 06:45 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
no crazy is buying a Yaris then modding the crap out of it , but boy it's fun and as you know entertaining
Old 04-12-2009, 05:05 AM   #4
fuji
fuji's Avatar
I have to agree!
Old 04-12-2009, 05:42 AM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Okay lets get back on track, Engine damper
as eTiMago said the shock that i showed on pg1 and or infact any air /gas
shock would more than likely be too soft,which is true to a piont .
the thing to remember is,that it is a shock absorber , it has 20x's more
travel than a nitto damper (rubber ring filled tube) which basically has no travel at all .
it's like filling your engine mounts with a resin (it takes away movement).
But it induces vibration into the car , true or false .
what i am trying to say is that even though the the gas /air shock might
be too soft for track conditions it might be perfect for those that don't want the vibrations , or require such harsh dampening .(street conditions)
some is beter than none , or even too much .
i hope all that made sense.if not just shoot me now . and i will go away quitely
Old 04-12-2009, 02:31 PM   #6
fuji
fuji's Avatar
I think what you are saying makes sense. It is possible with a stiffly sprung short travel motorcycle of MTB shock to have an improvement in the rocking motion of the engine with minimal vibration.
Another idea for decreased vibration is to have some type of vibration dampening material where the engine damper mounts to the body such as a large rubber bushing. Even if there is a small reduction in the vibration from the rubber/soft polymer, it may make a significant difference.
It sounds like the best option after all the brainstoming here is very short travel, stiffly spring suspension unit. After hearing the basic technology in the nitto dampener - Nitto is making quite a profit on this product.
Another possibility is making the DIY damper two-sided therefore increasing the stiffness. May also have a positive benefit if there is a tortional component to the engine movement.
Old 04-16-2009, 12:31 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Have fun.
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
engine dampener? cali yaris Performance Modifications 15 11-24-2008 03:36 PM
