Old 04-10-2009, 04:25 AM   #1
chinoken503
Drives: Yaris 07
What would happen if i get a low beam and i turn on the high beam? Would the HID blow?
chinoken503 is offline   Reply With Quote
Old 04-10-2009, 04:33 AM   #2
There should not be a high beam bulb. So I don't think anything will happen. hehehe. My HID low and halogen Hi has two bulbs. The halogen bulb is right next to the HID bulb, very small, and very useless.
Old 04-10-2009, 04:40 AM   #3
chinoken503
Drives: Yaris 07
So you purchased one of those HI/LO bulbs with an HID low and halogen HI that are fitted right next to each other? So if i get a single beam HID bulb and turn on high beam it should do nothing?
Old 04-10-2009, 05:02 AM   #4
Well, not necessarily, like the comment above, things just might get dark. Our cars shut off the low beams when the high beams are turned on. On my kit, there are two cables, one for the high and one for the low (HID), so if there is no cable for the high, there will not be a place for the power/wattage to go to/diverted to, so, nothing happens, nothing turns on.
Old 04-10-2009, 05:03 AM   #5
chinoken503
Drives: Yaris 07
hmmm i c, I guess i will have to look and see how my wiring is like.
Old 04-10-2009, 05:04 AM   #6
chinoken503
Drives: Yaris 07
thank you everyone for your advice
Old 04-10-2009, 04:52 AM   #7
AlainMikli
AlainMikli's Avatar
if you using a single beam HID, if you turn on the High Beam, may be everything will turn off.
my friend's has a fits after install hid, the high beam will turn off everything~
but after some wiring he seems to get rid of it, nothing happen when turn on the high beam~
Old 04-10-2009, 04:57 AM   #8
chinoken503
Drives: Yaris 07
So turning on the high beam will turn off the Low beam HIDs when enabled if i only have a single low beam?
HID Question!! MurderCivic Cosmetic Modifications (Exterior/Interior) 4 01-21-2009 03:29 AM
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
