Old 04-28-2009, 09:56 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Has everyone else already recieves their stalk switches?
Old 04-28-2009, 10:01 PM   #2
mrbond
mrbond's Avatar
Nope. Still waiting impatiently.
- A Toyota Yaris
- A whut Yaris?
Old 04-28-2009, 11:17 PM   #3
MGargano
Drives: 2009 Yaris Hatchback
Ditto. Should be any day now I hope. I have an '09 so hopefully the install should be simple.
MGargano is offline   Reply With Quote
Old 04-29-2009, 02:39 AM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
CTSscott, is your setup able to be cancelled by pressing the brake? and can you over-ride the set speed with acceleration to a new speed and then pressing set again?
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-29-2009, 07:58 AM   #5
Yes - Brake (or on/off button) cancels it and I can accelerate and hit set again to lock in a new speed.
Old 04-29-2009, 01:43 PM   #6
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
very nice! given my expertise with cars, this will be a fun summer project! lol
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-29-2009, 02:22 PM   #7
AlexNet0
AlexNet0's Avatar
it wont be an issue as long as I can find the pin under the dash with help from PK's writeup or instructions/pics, whatever, lol
Old 04-30-2009, 12:36 AM   #8
I just posted a DIY for those with 09s, who wish to use the switch method:
http://www.yarisworld.com/forums/sho...783#post302783
Old 04-30-2009, 11:09 AM   #9
33OH
Drives: '08 Yaris
Hurry up PK!
Old 04-30-2009, 02:30 PM   #10
Pitt Yaris
Drives: Flint Mica Sedan
Very cool, I'm thinking of mounting the switch where my auto mirror adjustment would be to the left of the steering wheel
Old 05-01-2009, 10:10 PM   #11
I just added a note on my DIY in regards to cars with MT. TDB-1 PM'd me tonight. He attempted the two button method on his 09, and the on/off worked, but not the set. He inquired if there was anything different about a MT, and it turns out that the MT requires a second switch on the clutch for cruise.
The "Cruise Control Clutch Switch" is needed as well. This is a second clutch switch (there's already one called the "Clutch Start Switch"). The "Cruise Control Clutch Switch" connects to connector A29. Its part number is: 88280-14030 and it lists for ~$18.
Old 05-01-2009, 10:36 PM   #12
ahhh so its not the same as the clutch switch for the ignition inhibit
Seems pretty silly, except the start one detects fully pressed and the cruise on detects the initial press of the pedal.
Old 05-02-2009, 01:37 AM   #13
MGargano
Is the 'Cruise Control Clutch Switch' only needed if using your two button method on a MT? Will I still need it if I'm using the OEM stalk?
Old 05-02-2009, 05:09 AM   #14
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Damn damn damn! I have an 08 MT. That's 2 strikes. My dream of $20 OEM CC is fading fast...
Old 05-02-2009, 08:57 AM   #15
Yes, the clutch switch is just for MT, and it is still needed with the OEM stalk. It keeps the car from over revving if you press the clutch while in cruise mode.
Old 05-02-2009, 11:37 AM   #16
TDB-1
Drives: 09 3-door 5speed
cruise
Ok I just finished up my 2 button cruise setup on my 09 3 door 5speed. I did everything as per the DIY and it works great!!!! I had to jump the clutch switch for the test until I get the correct switch. This works just don't step on the clutch while on cruise or the engine could over rev. I got my switches at Radio Shack for $2.69 each and they look identical to the ones in the DIY. I used 2- 330 ohm resisters also from Radio Shack that cost $.99 for a 5 pack. This is the best thing I did to the car since I got it. THANKS to all who figured this was possible
TDB-1 is offline   Reply With Quote
Old 05-02-2009, 11:24 AM   #17
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
There's no way of rigging your own MT Clutch Switch for doing this DIY? Not that 18 bucks is that bad, but if you didn't want to wait around for the thing to show and could possibly use some stuff you have laying around in your electronics drawer?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-02-2009, 12:09 PM   #18
nickhjort
nickhjort's Avatar
Also I searched quick and I couldn't find anything on removing the dash for the 07 liftback 3dr. Does anyone know where I might find a quick reference guide?
My Car Rules!
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
