I love momentum.
Just as a side note, I think it would be worthwhile if a mod re-named this thread to something like "DIY Cruise Control how-to, 2007-2009".
The current thread title won't be helpful in future searches :D |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Alright you guys, I'm home and I used my Cruise Control to and from work...it was GREAT! Definatly worth the trouble. But of course right now it's kind of a pain to always be wondering "Did I turn it on yet? Is it on or off right now? I sure wished this LED worked." :)
I just got done reading all these replies. I will definatly take the meter apart again and check all those pins "just for the heck of it," cause it will be nice if that works out. But if not we'll have to figure something else out. PK198105, no I don't have the tach in the combination meter, but I did install one aftermarket...I think that doesn't effect this process. And I do also see many empty solder points on the PCB...LED's, IC's and some other stuff. Also, I didn't see the clutch switch wire hanging down under the dash, but I will search again just to make sure. Anyway, I probably won't have any time to do this until saturday, so hang in there guys and I will keep checking in here everyday to see what's shakin'. I will post more pics on saturday with my results from the voltage tests. Thanks guys!
My Car Rules! |
#4 | |
Sounds good. I have a circuit design in my back pocket for making the LED work, without changing to a dual pole switch, in case we need it... |
Nice.
My Car Rules! |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Any ideas on where I can find a steering column cover that already has the opening for the cruise stalk? My car's basically brand new and I don't wanna mess up the OEM cover if I can help it.
SIPNDEW
i thought the cruise came through the steering wheel, not the column cover?
Cover, Steering Wheel Boss, Lower: 45184-52130-B0
This is for one that has factory cruise control, (and it is the plastic back of the wheel, not the column cover). |
Ohh so it's actually the back of the steering wheel, not the column cover? Doh! This fits & color matches the US 09?
Thanks, just ordered from TRDSparks. Should be getting the fogs, OEM combo stalk, shrouds, clutch switch, and boss this weekend to go with the cruise stalk. I figure I'll pull the steering wheel once and be done with it.
CTScott, I checked every pin (just to be sure) on those two IC's (IC500,IC501) and the pins for the blank spot where the third IC should go (IC502). Nothing :( they were all the same after I hit the Cruise switch. I grounded my meter to the frame and checked the pins with the red lead of the meter while it was on DC Voltage "20V" setting. That's how I do it right (I don't think I'm that dumb, but just to make sure) I guess it's not gunna happen the easy way as usual :)
My Car Rules! |
#14 | |
Sounds like you tested it correctly. As PK mentioned prior, there was little chance that it would be there, but it was worth a shot. I have to order some parts today for another project, so I'll order what I need as well to test my method of lighting your LED. |
#15 | |
I received the parts this week for lighting your LED, without changing your switch. I will be using a PIC12HV615 microcontroller to sense the switch press (and differentiate between the on/off and one of the other ones being pressed) and to drive the LED. The entire circuit will only require the 8 pin microcontroller, a transistor, and a few resistors (totaling maybe $5 in parts). I will hopefully have some time this weekend to experiment. PM me your mailing address, and when I have it all figured out, I'll mail you the "module" (at no charge, since you've been the guinea pig for this). |
Awsome. Thanks.
My Car Rules! |
![]() ![]() Drives: '07 Yaris 3D HB Auto Join Date: Jul 2007
CTScott and nickhjort, you guys are awesome. keep up the good work.
this info is super helpful. i will do this on my car once i have some downtime. i have an 07 auto, FYI. |
Thanks. It feels good to be able to actually help for once instead of just sucking in all the information and hard work of others to make my car better :) I like being one of the first to do a mod.
My Car Rules! |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 02:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
