Old 05-09-2009, 05:47 PM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Also I'm probably going to try to make my own clutch switch, seeing as it's only a momentary switch held down bt the clutch. I'd rather spend another 2 bucks on the switch then 19 at the dealer. I'll post pics once I finish it.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-12-2009, 06:16 PM   #2
mrbond
mrbond's Avatar
So...theoretically I wouldn't even need to remove the dashboard if I'm using the stalk. If I reuse a ground point on the driver's side kick panel next to the hood release, and just thread all the necessary wires through the firewall, then that's the end of that. Now, this is exciting.
- A Toyota Yaris
- A whut Yaris?
Old 05-12-2009, 08:07 PM   #3
Definitely don't remove the dash, since the junction point under there is not populated. It's just a straight run from the stalk connector to the ECM.
Old 05-12-2009, 08:14 PM   #4
mrbond
mrbond's Avatar
By the way, if anyone has the clutch switch on hand, could you post a picture of the connector? I believe I may have found the necessary wire plug. It was taped up with a bunch of other wires by the clutch pedal, so....
- A Toyota Yaris
- A whut Yaris?
Old 05-12-2009, 08:31 PM   #5
The connector is a two pin one with a black and a blue wire.
Old 05-12-2009, 09:54 PM   #6
mrbond
mrbond's Avatar
Well, I found an unused wire plug, but it's clearly the wrong one. I wonder what this one's for?
Anyway, AllexNet0, I'll be installing the stalk on sunday hopefully. I'll take a bunch of pictures for each step of the way. And we'll see what happens with the clutch switch wiring that nickhjort was talking about.
- A Toyota Yaris
- A whut Yaris?
Old 05-15-2009, 06:08 PM   #7
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Hey nickhjort, did you ever figure out that homemade clutch switch? I think a lot of us are anxiously waiting to see if that works! Let us know asap thanks!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-15-2009, 11:46 PM   #8
nickhjort
nickhjort's Avatar
Yeah tomorrow I will be "frankenstein"ing it together. I haven't had time yet, but tomorrow I will hopefully have it done, and I will also mock up an exhaust idea I had. I will take pictures of both :)
Motorcycle Exhaust on a Yaris!
My Car Rules!
Old 05-16-2009, 05:35 PM   #9
nickhjort
nickhjort's Avatar
Pics for now... I will take more in an hour or so when I get it put in...it's raining like a mofo here now...
This is my switch I bought at radio shack. You get four in a pack for 3.59 I think.
Aluminum bracket, switch and bolt that replaces stock clutch switch.
My Frankenstein (It's ALIIIIIIVE!!!!...almost)
Just make sure you have a SPST switch that is normally open...not closed. Also make sure it is long enough to touch the little black plate you see in the picture. I think mine is barely gunna work. If not I will probably epoxy something onto the end to make the button part longer. We'll see in a few.
My Car Rules!
Old 05-16-2009, 06:09 PM   #10
nickhjort
nickhjort's Avatar
Well the switch was just barely too small. So JB Weld time...
I used a cap from a can of liguid wrench :) Now it truly is a frankenstein haha. But it's all good. Nobody can even see it unless they stick their head under the dash. Anyway more pics to come soon when it's installed in the car.
My Car Rules!
Old 05-16-2009, 08:52 PM   #11
nickhjort
nickhjort's Avatar
Alright peeps, it's in. It works so far when hooked up to the meter. Tomorrow I'm gunna wire it in and test her out. Now all I'm waiting for is the led "module", courtesy of CTScott then I'll be all set
My Car Rules!
Old 05-17-2009, 03:53 PM   #12
Nice job with the DIY switch. Hopefully this week I'll be able to ship you the module for driving the LED.
Old 05-18-2009, 05:34 PM   #13
PatrickJohnson
Drives: 2008 Yaris LB
a quick diy on the PIC programming you used and the circuit would be great too!
PatrickJohnson is offline   Reply With Quote
Old 05-18-2009, 07:18 PM   #14
I finally got around to prototyping it last night. Tonight I'll try it out on my car, and if all is well, I'll post the info on it.
Old 05-19-2009, 12:03 AM   #15
nickhjort
nickhjort's Avatar
Awsome. I'm glad everyone is having such good results with this project, minus mrbond, but you'll get it. Check your grounds :)
I got my clutch switch up and running today. It works just perfectly, but it truly is a frankenstein :) I will take some pics of the final setup when I get some daylight. You may want to just spend the 18 bucks and get the stock switch. It will definatly look way nicer than my setup. But no one will ever see it anyway, so if it works then who cares right? plus I only spent 3.50 for the switch. I had everything else on hand.
I can't wait for the LED module CTScott :) After that, my install is complete and I can finally take all the tools out of my car HAHA! Also let me know the cost of parts for that module so I can add that into my total cost...even though it will be a gift
My Car Rules!
Old 05-17-2009, 03:56 PM   #16
nickhjort
nickhjort's Avatar
My Car Rules!
Old 05-17-2009, 07:32 PM   #17
zlh99a
Drives: 2008 Hatchback
I just did this mod using nickhjort's method. Many thanks to nickhjort and ctscott! You guys rock!!!
zlh99a is offline   Reply With Quote
Old 05-18-2009, 06:09 PM   #18
mrbond
mrbond's Avatar
Well, I installed everything Sunday. Didn't work, which means I'll have to buy some spade connectors. Might just be the ground, but I'll keep trying.
- A Toyota Yaris
- A whut Yaris?
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
