![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
^ you need wires going from the ECM to the little hub in the steering wheel column, a wire going from that hub to a ground point, and the stalk, and then a jumper wire for two pins in the engine bay. Everything's been outlined and explained, so you just need to read carefully. That's about it. I'm selling my stalk btw, since I just don't really want it.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
boydstir
cool thanks for the input
![]() Drives: 09 LB, 3 door, auto Join Date: May 2009
So it should work ..
I have 09 3 door liftback, and it seems all I need is a stalk. Could someone give me a link to where you got the stalk ? Thanks a lot for the investigating this !
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
#5 | |
http://cgi.ebay.com/ebaymotors/TOYOT...lenotsupported or TRDSparks.com ($81.99 plus shipping): part number: 84632-34011 |
![]() Drives: yairs blue 2007 automatic 1.3 Join Date: Apr 2007
i am going to try this soon as i get bk home next month i have 07 yaris i just hope ull all b here to ask for my questions
I don't think it will work on your car. On European manufactured Yaris cruise control is not an OEM option, so the ECM doesn't support this mod.
![]() Drives: 5 door hatch Join Date: May 2009
Ok, after reading all these posts I am now REALLY confused so please bear with me since I am also new here. I have an '09 S 5 door liftback, auto trans. In real simple terms since I am not an electrical engineer, what do I have to do to have the factory cruise installed. The dealer wants over $500 for an aftermarket one which is ridiculous.
#9 | |
Or, check out this thread for adding cruise to your 09 auto for about $10: http://www.yarisworld.com/forums/sho...ght=diy+cruise |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
Just to confirm after reading 24 pages.....this will work on an '08 MT but you need the stalk, the clutch switch and need to do some wiring to the fuse box, correct?
That would be AWESOME. Thanks for all the info so far guys, great job.
when I finally get around to doing it, I will make one, however it will be the stalk method, since I like more of an oem look.
I have a 08 mt lb and a stock, lets do it.
For your MT you're going to need the clutch switch as well. It's OK to bypass it for testing, but for normal use you really should have it in place.
Anyone else from the New England region interested in doing theirs? We could do a DIY cruise control workshop. |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
I may move the led I have mounted next to the switches up into the guage cluster before I install the LED module CTScott has provided. Make it look a little more stock-ish. Also scott, if my LED is too bright I can just add a resistor of my choice in series and that'll dim it down some correct? And also I'm going to just buy the stock clutch switch for 20$ from the dealer, rather than try to fix the frankenstein I put together :)
My Car Rules! |
#17 | |
A workshop would be great.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 02:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
