Old 07-14-2009, 02:53 PM   #1
Brentorius
Drives: 07 Mazda MX5 Copper Red
Smile
Good read!
Any updates on an 09 yaris MT? Any confirmations regarding the connector for the clutch switch?
Parts needed:
Clutch Switch: 88280-14030
Steering Cover: 4518452130b0
Stalk: 84632-34011
I already ordered the stalk on ebay for $29.99 shipped.
-Brent
Last edited by Brentorius; 07-27-2009 at 02:03 PM. Reason: Corrected part # Steering cover
Brentorius is offline   Reply With Quote
Old 07-20-2009, 01:32 PM   #2
Vince87
Drives: 2007 2DR Yaris
Wow ! thats a quick reply ! I'm trying that right now, I'll tell you if it works in 10 minutes...
Vince87 is offline   Reply With Quote
Old 07-20-2009, 02:15 PM   #3
Vince87
I soldered every connections real bad and there's still nothing happening... If my understanding is good all I have to do is get to >40 mph (~60km/h on my canadian car), press the on/off button (with black and red wires) and then press on set, is that it !? If it's a ground problem, can I use a ground wire somewhere to make sure that it's not my connection to the chassis that is bad!? thanks for you help !
Old 07-20-2009, 03:18 PM   #4
That is correct (it's actually >25 mph). Just to clarify, the on/off switch is the one before the resistor and the set switch is the one after the resistor.
By the way, I believe that you are the first Canadian trying this.
For a ground, The bolt that you posted the picture of is a great ground point. You can strip about an inch of insulation off of the wire, wrap the wire around the bolt (under the washer) and crank the bolt back down.
Old 07-20-2009, 04:24 PM   #5
Vince87
Alright thanks for clarifying this point ! By the way in the meantime I tried to ground it on the battery with a wire going out the window without success... I verified if there was an internal resistance in my switches but there's none... I've been working on it (mostly making trials again and again) for more than 6 hours and I'm actually wondering if something is different on the canadian version !!??
Old 07-20-2009, 04:42 PM   #6
PatrickJohnson
Drives: 2008 Yaris LB
just to be clear, you know you have to have the resistors in place, correct? A simple grounding of the pin 40 wire will not trigger the cruise, you need those resistors wired to the switches...
PatrickJohnson is offline   Reply With Quote
Old 07-10-2009, 06:05 PM   #7
ecnal
Drives: 09 Yaris Sedan AT
Well, I'm guessing that a column cover wouldn't run all that much. Plus about 30 total for a stalk assuming you buy one on ebay and not find one at a yard somewhere. Outweighs the cost of having it installed at the dealer! Plus it probably adds a little bit of resale value to it.
ecnal is offline   Reply With Quote
Old 07-10-2009, 07:31 PM   #8
FunkyCole
FunkyCole's Avatar
Drives: 07 Toyota Yaris
Did this work for any of you?
FunkyCole is offline   Reply With Quote
Old 07-10-2009, 11:31 PM   #9
Yes. I installed it using my $10 switch method on my 09. Quite a few have now done it on 07's through 09's.
http://www.yarisworld.com/forums/sho...ght=DIY+cruise
Old 07-15-2009, 08:39 PM   #10
FunkyCole
FunkyCole's Avatar
Did any of you guys find out if this works?
Old 07-20-2009, 01:13 AM   #11
Raist17
Raist17's Avatar
Drives: '07 Red Yaris hatchback
First of all I'd like to thank everyone who's been putting so much work into this, A+ job guys!
I'm looking to do this on my '07 AT hatchback, can't find a stalk on ebay so if anyone has one laying around PM me and I'll buy it off ya
after I get that accomplished I may hit you up CTScott about one of those LED array thingys... then I can prolly throw together a DIY for the 07-08 AT crowd once I get the parts :D
-- all stock 2007 Yaris Hatchback, Red --
Raist17 is offline   Reply With Quote
Old 07-20-2009, 05:12 PM   #12
What he said, plus make sure the switches are N.O., not N.C.
Old 07-20-2009, 06:13 PM   #13
Vince87
I do have a multimeter, and get a 630 ohm reading when I check the resistance at both ends of the resistors with both switches pressed.
The switches must be N.O. because if I dont press on both I dont get any reading. It's the 1st time I'm using a multimeter how can I verify the continuity of my switches??? thanks again
Old 07-20-2009, 06:24 PM   #14
With the switches you should see a high value or OL when they are not pressed and 0 ohms when they are. Or, in circuit 0 when on/off is pressed an 630 ohms when set is pressed.
Old 07-20-2009, 06:52 PM   #15
Vince87
My friend, you might have found my problem !
- When on/off is pressed i get a 530 ohms reading
- When set is pressed, i get 624 ohms
I have no idea why I get this 530 ohms reading... I might make another set of switches since I have 2 other swithes a lot of resistors...
Old 07-21-2009, 02:44 AM   #16
Revsson
When in the Ohm setting, did you touch the two probes together and
get 0 Ohms? Just checking to see that the meter is calibrated, which
could throw off your readings.
Old 07-21-2009, 08:46 PM   #17
Vince87
Yes I did, my multimeter is brand new so its probably well calibrated...
Old 07-21-2009, 10:55 PM   #18
Did you get a chance to swap that switch out? If not, before you do, check the extra switches with the meter to make sure that they're OK.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
