Old 04-12-2009, 05:08 PM   #1
newyar
Drives: Yaris Liftback 2008
Having just installed one (this morning), I can say I'm rather amazed at just how much difference it actually makes. To be honest I wasn't really expecting much but the kit I got was fairly cheap so I figured it was worth a shot.
I took my time to think about what should be grounded and where; I only put grounds on 3 points so far but what a difference it's made. I put a ground wire on the throttle body housing, the alternator bracket and the computer bracket on the firewall. I figured those 3 areas are the ones that need voltage stability the most.
The results? I noticed it immediately when I started the car; the engine idles silky smooth and it's noticeably quieter. In fact if I couldn't hear the engine running I'd be hard pressed to tell if it's even on. It made that much of a difference. There's no vibration now through the pedals...it's kind of eerie actually.
When driving I can't feel any power difference; if there are any gains in this area it's not enough to feel. What I did notice was how smooth and quiet the engine runs now. It definitely runs quieter which is something I didn't expect. I even turned the A/C on which usually causes a little bit rougher idle but I couldn't tell any difference with it on or off. Idle is smooth no matter what; when running with the A/C on, the engine is still smooth, stable and quiet; you just can't feel it running through the pedals. It's almost like I'm driving a sewing machine now.
I'm looking forward to seeing what difference this makes in mileage if any, but even if it doesn't I'm sold just on what it does to smooth things out. For less than $20 this is WELL worth it.
newyar is offline   Reply With Quote
Old 04-12-2009, 10:14 PM   #2
supmet
Drives: 2007 4 Door Yaris
I'm sold!
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
What's the difference in the Door lock Kits (wire and rod) mgthompson General Yaris / Vitz Discussion 5 03-19-2007 01:29 AM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
