Originally Posted by The Spectacle
The carpet....eh. The carpet doesn't match because the Yaris has some off color cheapo carpet...the carpet that's on the kicks is going to be the same thats used on the amp rack cover I'm about to get installed today. It does stand out as much as it doesn't in the pics, but its not really all that bad. I mean, who stares down there anyway? You can't see it unless you're looking for it. And it certainly won't look that off in the rear where the seats are the same color right in front of the amp rack/sub box.
Yeah, the carpet they used is a good carpet, the Yaris isn't exactly a Lexus despite my work to make mine sound like one on the inside. And that works too, wasn't sure if you intended to hide the amp and other gear on the side-shelves in the back, or wanted to leave all that gear exposed a bit yet. And it's not bad at all, it's good construction they did back there too.
I'm going to also consult with them today about my time alignment options. Now that I've had the weekend to sample everything, I curious as to how much of a difference a properly setup processor will do.
It makes a world of difference once you hear it in action. Instead of just shoving the positioning around crudely, suddenly things will be 'exactly THERE' and playing with the fade/balance on the head unit will just sound like you're turning down the volume in one area instead of moving the sound around. At least, that's been my experience with a well-tuned time alignment processor in play, but that was riding in a friend's 911.
