Ok,i get in the car this mornig to go to work,after i start it,the tire pressure sensor light is on,so i think that i have a low tire,after work,i check the pressure in all my tires,found the air pressure was low in the spare,filled it up to 60 but the light won't go out,all the other tires were properly inflated,do i have a bad sensor or do i have to reset it somehow?
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
Is that PSI? I think 60 PSI twice as much air as you should have in a spare tire. My dads 10 ply tires have a max of 50 PSI and a donut should be 2 or 3 ply.
I did some searches and did not come up with the specks for the OEM sensors. But you could have a low battery in one tire.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. Last edited by firebob; 04-08-2009 at 08:51 PM. Reason: added info but not worth a new post |
The Yaris TPWS doesn't monitor the spare - It just looks at the 4 mounted tires.
Check out this post for a method of finding out what the error is without having to go to the dealer: http://www.yarisworld.com/forums/sho...8&postcount=11 |
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
More options more goes wrong I think.
I would have never thought a donut would be 60 psi.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
Half a Bubble Off Plumb
Yep, it's true.
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Compact spares are basically always ultra-high-pressure tires, 60psi is almost a standard. I've had some cars that uses as much as 75psi or 80psi in the spare.
well,for some odd reason,it went off tonight,it was on when i came home from work,but when i went back out to the store,it was off,so hard to tell what was wrong
The TPWS keeps its trouble codes until they are cleared with the Techstream tool, so even if the light is now off, you should still be able to find out what the issue is using the procedure above that I posted the link to.
![]() Drives: 09 2 dr, 5M, Yellow Join Date: Apr 2009
700 cc bicycle tires carry over 110psi.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
And that's sad.
| Higher Tire Pressure | captainm27 | General Yaris / Vitz Discussion | 46 | 01-27-2009 10:17 AM |
| Tire Pressure Monitor Sensors....? | 09TRD | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-19-2008 09:25 PM |
| Tire pressure sensors | Tink1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-21-2008 05:53 PM |
| 2008 Yaris with Tire Pressure Sensors | nsmitchell | General Yaris / Vitz Discussion | 2 | 08-23-2007 11:34 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
