since this is DBW, im pretty sure toyota has removed one of the units that control the cruise control.
PK, if you have time, could you look at the complete wiring of the cruise control ? does it end at some place where there should be a box, but it isn't there?? also, the last thing i know, that if i got the cruise control from Toyota (back in late 06), i would not have gotten the OEM cruise control system... |
#2 | |
![]() Drives: 2008 Yaris 5-door Join Date: Mar 2009
#3 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#4 | |
I was just thinking out loud. I basically removed the clutch switch and the starter is permanantly enabled, not just when the clutch pedal is pressed. When i do this, if it works, I will have to install another switch.
Does this mean, if all goes according to plan, that I'll need something other than the eBay stalk to make this work? This is assuming, of course, that the eBay stalk does what we all hope it will.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
