#19 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Congrats on your new Y! Yeah we got stuck with an Emo of a clutch, but you won't even notice it after about a month
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I only test drove the MT Yaris once and all I remember was it took alot of clutch pedal release before the clutch engaged. By that time I had the engine rev'd up really high because I had started pressing the throttle. The car salesman even asked me if I'd ever driven an MT before. (I've owned three MT cars)
Is that the same thing you guys are complaining about with the MT clutch?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#21 |
yeah, my problem is more with the DBW + clutch -- the pedal is laggy so it's harder than usual to finesse 1st gear.
#22 |
I just stomp the throttle and when I start to hear it roar, I pop the clutch. Problem solved.
lol jk, jk, jk, that would be horrible on it after a while |
#23 | |
![]() Drives: 2008 3 door LB Join Date: Apr 2009
And i prefer to wax by hand (i dont have an OB )http://meguiarsonline.com/forums/sho...&threadid=6442 |
#24 |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
I didn't know Meguiars has a forum. Good tip!! Thanks
#25 | |
. Yeah, it does take a while.
#26 | |
#27 |
Well i did a wash, claybarred, and waxed my yaris earlier today. I wasnt able to get good pictures outside because it was so bright...the pictures just didnt look good. So i pulled in to my garage and took some shiner pics. My personal camera has gone missing so i used my mom's coolpics camera with a low battery.
Sorry no wax on wax off pics... ![]() ![]() I use Meguiar's products exclusively when detailing. More specifically the Deep crystal car wash, Smooth surface claykit, and the Gold Class Wax Paste. Applied with the supplied applicator pad and removed with microfiber cloths. |
#28 |
How long did it take you to claybar the whole car? |
#29 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
i guess I've never heard of a claybar....
explain.
-Jen <3 ![]() Quote:
#30 |
#31 |
Using a claybar before waxing or polishing is a must IMO. What you do is you take a piece of clay (automotive clay such as the Meguiar's kit), you spray a lubricant (in this case Meguiars Quick Spray wax or w/e it is), and you rub the clay along the paint covering all areas of the car. What it does is it removes dirt and other things that a normal soap wash couldnt remove. Once you are done claying a portion of the car, you will notice the clay will become dirty on the side you rubbed. You simply fold it over and over again till you're done with the entire process..
The purpose of this is to remove dirt that wash didnt, and to make the paint feel smooth. It is also used to strip older wax in order to put on a new coat (although not always necessary). After you're done claying, and waxing...the claybar step makes the wax feel even smoother. Tomato.. The claybar process is the shortest IMO. Took 10 minutes for me to cover the entire car. Took 45-60 minutes for me to hand wax. EDIT: this is a picture of the clay that i used about a year ago on my truck. The picture was taken after i claybarred the roof of my Ford Ranger... ![]() the pic is slightly red because of the camera. And yes that is a hair on the clay ... >.> |
#32 |
Dude, I know exactly that route that you're in. Its Arrowhead isnt it?
BTW, getting used to the Yaris clutch makes me drive a S2k like a noob. Its great. |
