Increased MPG or HP anyone????
Was curious if anyone was experiencing an increase in miles per gallon or horsepower with an aftermarket Intake or exhaust. I was curious to know if an intake or exhaust would benefit other then looking/sounding better. Let me know what you all are using and your thoughts on the product.
Give me a couple of weeks and I'll let you know about the AEM cold air intake.
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
Not so true Yaris TTe,I have a TRD CAI,And I noticed a 3-5% increase in milage,no bull.Actually if you are easy on the throttle at all times,you will get an improvment,but ofcourse when you get the CAI or exhaust,you always want to accelarate faster,because now you can.With the CAI,it actually is like compressed/denser air,which will cause your car to use less gas.zthink of it this way,if its real hot out side,air is less dense,so your car replaces lost air with more gas,so when the air is cooler via cold day or CAI system,them you will have better combustion using less gas,its that simple.As for exhaust,it helps reduce back pressure,and at the right rpm will increase the pulse performance,it like it creates a outward vacum that actually helps pull the exhaust out.If you have both CAI and intake,you will get good improvment if you are easy on the throttle,but can you resist when you get those new performance parts.And you cant compare a ferrari with a 4 banger,you dont even want me to start and explain why a ferrari uses more gas!!!
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
I have a TRD cold air and have noticed some MPG improvment, but, as eco stated, I romp on her a little bit more so it is only like 15-20 more miles per tank. hey even rompin on her hard I am gettin 30-33 MPG
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
When my OEM tires expire, I may buy a set of tires with lower rolling resistance and I believe I will get slightly better acceleration and slightly better fuel economy as a result.
The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
The only way adding an intake will decrease your mpg is if your busy gunning it all the time to hear the noise of it. When You add these bolt ons such as intake, header, exhaust, it only improves fuel efficiency. Adding more power to the vehicle only makes it easier for the vehicle to move itself. Meaning the engine has less struggle getting the car moving, and also means you are able to apply less gas to get to your desired speed at the right amount of time.
Yes you are adding more air into the engine which helps increase combustion, but you are not adding more fuel to it unless your running an aftermarket ecu. Adding an intake will not make your ecu send more fel into your engine to compensate for the "extra" air. It's set to what it is, and that's that. If anything with all bolt-ons most cars end up running lean if they don't have an ecu to tune with because the factory ecu will not automatical ajust itself and send more fuel. While this is good for gas, going to lean is not good for the motor on the long run....especially if your always pushing it.
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
The LittleBastard
and if you need an example.....
when I had my S bone stock I was averages with calm driving around 200-210 on a full tank. After adding my intake/header/test pipe/exhaust/flywheel I was making close to 230whp(this was all on the stock ecu). After all those mods I was averaging with calm driving 235-245 on a full tank.
Basic thermodynamics tells you that all other things being equal, when you lower the intake temp, you'll increase effeciency.
#9 | |
![]() ![]() ![]() Drives: 2011 Rogue Join Date: Jan 2006
![]() ![]() ![]() ![]() ![]() Drives: icebox Join Date: Apr 2006
Hey Jcove, long time no see!!! Glad to see that you got things worked out with Vibrant, can't wait to see the pics!!! Hey let me know if you're coming out to the fall tour this Sunday....
#11 | |
![]() ![]() Drives: '00 s2000, 2007 yaris hatch Join Date: Jul 2006
Get the intake! |
#12 | |
![]() ![]() Drives: BBM Yaris HB Join Date: Apr 2006
yes, you may be using less fuel to go the same speed, which is why mods usually increase mileage, but it does not change the rpm-speed relation in any way. |
Your wrong Ron.Even when Im behind a trailer,I notice a diffrence in rpm's at a set speed.I have a ScangaugeII and a tach,I know what Im talking about.Laws are made to be broken,and I know for sure thats not a law.
#14 |
Look mum no stars!!
Wow there is gonna be a great debate here.
My yaris - gained some Hp with my new muffler, but i dont take that much notice with my MPG
#15 |
same here, small gain with muffler only, nothing measurable mpg wise though, if there is a difference its not big.
#16 |
Look mum no stars!!
Ya its always good to get something out of your mods, emotionally or performance wise.
Like i always say "better than nothing"
#17 |
With the AEM CAI and TRD exhaust I'm getting 1 or 2 more mpg based upon a decent number of fill ups.
Also its more fun to drive, sounds great and looks better. Win/win. |
#18 |
yep I did it just for the sound, really.
| New to Yaris ? Check in here !! | VitzBoy | General Yaris / Vitz Discussion | 1960 | 02-02-2026 10:14 AM |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 08:15 PM |
| 38 hwy miles per gallon, lol, you kiddin me? | pennystocks | General Yaris / Vitz Discussion | 70 | 09-29-2006 08:13 PM |
