Old 04-17-2009, 12:18 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
Originally Posted by hatchbackkid82 View Post
Wait so with the Scangauge hooked up to the car, your telling me the CEL never comes on or it comes on you just turn it off. Have you tried adjusting the idle? It's really simple to open up, nothin in there for you to really damage
No, the CEL still comes on. I just use the Scangauge to turn it off right away. I haven't tried adjusting the idle yet. I'm not worried about damaging the stock TB, I'm just wary of opening it since it's almost brand new with less than 2,000 miles on it. If I open it up to do the chip swap, I want to know it's going to fix the problem.
MGargano is offline   Reply With Quote
Old 04-17-2009, 01:03 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
You won't damage the TB if you open it, since all you're really doing is drilling off some rivets. You can always get it sealed back up to OEM specs using a rivet gun (I used screws myself). I think you should give it a shot if you can and see if that solves the problem. Won't take more than 10 mins to do the swap.
Then again, you may want to adjust the idle screw first, which is even easier to do.
Old 04-17-2009, 01:11 PM   #3
MGargano
I guess I'll give the chip swap a try if the problems come back. I reconnected the battery and got no CEL or oscillation on start up this morning so I'll give it a few days *fingers crossed*
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 22 01-06-2009 07:34 AM
ambient map lighting? atebit Cosmetic Modifications (Exterior/Interior) 0 11-05-2006 01:15 AM
