Old 04-18-2009, 03:10 PM   #1
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
AWWW, id tell you but i can't stand you.....
Old 04-18-2009, 04:11 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Old 04-18-2009, 04:16 PM   #3
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Wow, that's a useful response. What have I done to offend you? I'm very sorry if I've hurt your feelings... did I insult your use of all-caps?
Anyhow, got the sensors off... screwdriver goes below the hole, push up, disengages it, plug slides off. Simple. Got the 4 bolts out. Now the whole hub won't move... figuring it's seized. Tried prying with a screwdriver, and hitting the backing plate with a rubber mallet. Would perhaps penetrating anti-seize stuff help? There's not much visibility from the front or the rear... not sure how much that would help.
Anybody have *useful* suggestions on how to get the hub off? Again, the Toyota factory manual simply says "Remove the 4 bolts and remove the axle hub and bearing from the axle beam." Hmmmmm... sounds simple!
2006 Red Blitzed RS 5-door
Old 04-18-2009, 04:30 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Sounds like the hub needs more gentle persuasion , try a bigger hammer with
some lubing agent .
Are you doing the disc brake conversion
Front and Rear Sensors ciscobadger DIY / Maintenance / Service 25 11-08-2014 10:52 AM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
