#22 |
![]() ![]() Drives: '10 Fit Sport MT and 2012 Fit Join Date: Oct 2008
In my opinion, the risks of causing harm to the engine while driving in a high gear at low speed is significant. Imagine riding a multi speed bike in the lowest gear uphil. This is the time when sproket and chains fail the most, due to highest load, on small number of teeth.
The power needed to turn the smaller diameter of a high gear is much greater than needed to turn (rotate) the lower gear. This stresses the engine, specifically it creates high forces on the crank shaft bearings, wearing them out prematurely. Another problem of loading the engine at low rpm is a possibility of inadequate oil delivery due to lower oil pressure at low rpm. Driving these new cars and not seeing major engine problems is not an indication that the engine is not wearing out prematurely. |
| Tags |
| gear changing |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 06:21 PM |
| Cold Engine and Gear Shifting | captainm27 | General Yaris / Vitz Discussion | 9 | 01-29-2009 08:27 AM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
