Old 04-18-2009, 10:19 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
ummm you did take the shoes off first right and everything inside the drum?
make sure the abs sensor is off, the 4 hub bolts are off and the brake line is disconnected from the backing plate.
then put two of the bolts about two threads in, and hammer out from the vehicle...
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-19-2009, 11:40 AM   #2
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Ummm... no? That might help!
Ok, doing more poking around in the service manual... Brake pg. 60: It says I have to drain the brake fluid. Do I have to? There's no way to leave it hooked up and just slip this spacer in behind the hub?
I hope I haven't messed up the alignment or hub bearings or anything from pounding on them with the brakes still attached and everything!
2006 Red Blitzed RS 5-door
Front and Rear Sensors ciscobadger DIY / Maintenance / Service 25 11-08-2014 10:52 AM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
