Old 04-19-2009, 03:43 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Originally Posted by andaconda View Post
Now can you tell us at what point the fuel is shut off to the injectors? IE: In gear coasting and at what RPM does the injectors open again? This is for us hypermilers.
Help me pick the parameters you want recorded.
Old 04-19-2009, 03:55 PM   #2
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
I'm not sure what parameters to use to find the answer to my question. Maybe someone could chide in here.
What I'd like to know is when the DFCO deactivates. Stick the clutch back in and the fuel is supplied to the injectors again. The subject has been brought up before to install a light on one of the injectors to see when it was activated again, but I thought your gauge might tell us that without the mod.
So... If I wait until the last moment to press in the clutch, at what RPM would that be?
andaconda is offline   Reply With Quote
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
Any body have good data on the Yaris fuel system? LtNoogie Performance Modifications 9 03-26-2009 08:01 AM
Black box data? jess General Yaris / Vitz Discussion 10 03-26-2009 05:34 AM
Data Recovery in CA. TEHxFALLEN V1.2 Off-topic / Other Cars / Everything else Discussions 7 10-27-2008 02:25 AM
