Old 04-17-2009, 12:06 PM   #73
tk-421
tk-421's Avatar
Drives: 5D-07-LB
It's weird how some ppl still gets CELs even after doing the chip swap. I still haven't had a CEL, and I've been driving it pretty hard.
I think it has something to do with the serial numbers located in the bottom of each TB, but I can't tell for sure.
Old 04-17-2009, 12:06 PM   #74
MGargano
Drives: 2009 Yaris Hatchback
Originally Posted by hatchbackkid82 View Post
One of the reasons i got rid of mine. I couldn't get the CEL off. I did everyting possible, always got a CEL, i went 2 days at the most, before it came back on. I'll try this mod again in a few months, hopefully someone would have come up with somehthing else to get rid of the CEL, i did the chip swap and everthing. Nice mod, though just don't like driving around with that light on
It's really not even the CEL that bothers me. I have the Scangauge, so getting rid of the light is a breeze. It's the start-up and random oscillation that's killing me. And I'd hate to break open my brand-new TB to do the chip swap and still be stuck with the same problem.
Old 04-17-2009, 12:08 PM   #75
hatchbackkid82
Drives: .
Wait so with the Scangauge hooked up to the car, your telling me the CEL never comes on or it comes on you just turn it off. Have you tried adjusting the idle? It's really simple to open up, nothin in there for you to really damage
Old 04-17-2009, 12:18 PM   #76
MGargano
No, the CEL still comes on. I just use the Scangauge to turn it off right away. I haven't tried adjusting the idle yet. I'm not worried about damaging the stock TB, I'm just wary of opening it since it's almost brand new with less than 2,000 miles on it. If I open it up to do the chip swap, I want to know it's going to fix the problem.
Old 04-17-2009, 01:03 PM   #77
tk-421
tk-421's Avatar
Drives: 5D-07-LB
You won't damage the TB if you open it, since all you're really doing is drilling off some rivets. You can always get it sealed back up to OEM specs using a rivet gun (I used screws myself). I think you should give it a shot if you can and see if that solves the problem. Won't take more than 10 mins to do the swap.
Then again, you may want to adjust the idle screw first, which is even easier to do.
Old 04-17-2009, 01:11 PM   #78
MGargano
I guess I'll give the chip swap a try if the problems come back. I reconnected the battery and got no CEL or oscillation on start up this morning so I'll give it a few days *fingers crossed*
Old 04-17-2009, 01:20 PM   #79
MGargano
No CEL but do you get the oscillation?
Old 04-17-2009, 02:17 PM   #80
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I get minimal oscillation (~300 RPM at the most) while running warm. Not too concerned about it myself. Pretty much the same as stock.
Old 04-18-2009, 05:24 PM   #81
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
i disconnected the battery today and followed the steps listed in the fist post
so far i have no CEL
so lets hope for the best!
i will post up my findings as i drive around this week
http://www.4055design.com
Old 04-18-2009, 06:02 PM   #82
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
please do you are my only hope lol
Old 04-19-2009, 05:00 PM   #83
kustom play
Drives: 07 liftback
well looks like good news
so i disconnected the battery for about 3 hours
came back and hooked it up started it up, it oscillated a bit then came down to normal
so i waited about 5 mins after that, then reved it up for about 3 more mins
after a while of reving the car started oscillating again so i stopped and let it settle
then i reved it back up for another 2 more mins and then went for a drive
i drove about 110 miles today with no CEL or no problems
looks like im in the clear
i hope it fixes the problem
Old 04-19-2009, 10:44 PM   #84
MGargano
I wish you all the luck in world and I hope this solves your problems. For me, after 3 days, the oscillation keeps getting worse and I've gotten several CELs. The chip swap is next on my to-do list.
Old 04-19-2009, 11:38 PM   #85
kustom play
Drives: 07 liftback
i did the chip swap already and the TB bypass so im hoping everything is solved
i'll have to wait and see
Old 04-19-2009, 11:45 PM   #86
MGargano
Originally Posted by Yaris T-Sport. View Post
hehe, should have done the chip swap in the first place, I'm now running with the 2.4 L Tc TB ( a little more bigger than the 1zz TB, yet a little more power ) with the 1nz chip for over a month with trouble free runs, no cel, no oscillation what so ever.
Do you still get the high cold idle with the tC throttle body?
Old 04-19-2009, 11:54 PM   #87
MGargano
Is this the tC TB you have? The 2AZ?
http://cgi.ebay.com/ebaymotors/04-05...Q5fAccessories
Old 04-20-2009, 02:59 PM   #88
Yoda
Yoda's Avatar
yes, which is normal due to the bigger TB opening, about 2.5k, then it sattles right away to 700s
Yes, and I swapped the chips.
Was that all nothing esle special done? I might just jump on this if no cel. Did everything work fine when you first put it on and what year exactly did you get?
Old 04-20-2009, 06:47 PM   #89
kustom play
Drives: 07 liftback
CEL came on about 120 miles
ohh well, to me it seems to have more power with the CEL on then without it
no big deal, my next emission test is 2012, i'll put the stock one in the week i go get that done
Old 04-22-2009, 02:09 PM   #90
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
did everybody trim the OEM TB gasket to allow more air flow as t-sport did?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 22 01-06-2009 07:34 AM
ambient map lighting? atebit Cosmetic Modifications (Exterior/Interior) 0 11-05-2006 01:15 AM
