Old 04-20-2009, 03:24 PM   #1
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
I just checked - my car ('08 5-door) doesn't have the wiring from the spiral cable to the ECM - nothing coming from that plug except the thin black horn wire. If the wiring for cruise were present, there would be two more wires.
So, installing cruise is probably still possible, but unfortunately it's not just a matter of adding a switch.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 04-20-2009, 04:00 PM   #2
My '09 has a blue wire in pin 1 and a brown in pin 3.
When I look at the models that the stalk part number is applicable to I see 06-09 sedans, but only 09 liftbacks.
Old 04-20-2009, 04:39 PM   #3
thats not where you connect the stalk to and the wire for css is already there,
wire 1 and 3 from the stalk is connected to 3 and 4 on the spiral cable
The stalk connects to the spiral cable on the steering wheel hub end, but the connector he pictured is the output of the spiral cable, heading towards the ECM. In his picture, the CCS wire (blue on my 09) is missing.
Old 04-20-2009, 05:37 PM   #4
Sir A.Y. Atoyot
Drives: '08 5-door
do you have that wire? the way i was looking at the ewd it seemed like these are used only as test points. either way it shouldn't be hard to just use the jumeper to connect the D3 with A21 i need to pop my cover to see better
I've done some research with the documentation that members have provided, and I can assure you that you need two wires coming out of that plug, in addition to the horn wire. One of them is blue and goes to the ECU. The other is a yellow ground wire.
Old 04-20-2009, 06:38 PM   #5
Sir A.Y. Atoyot
Drives: '08 5-door
....Anyways we shall see....
You said it.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
