Old 04-21-2009, 06:43 PM   #1
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Or you could add four momentary switches (On/Off, Set, Up, Down) to the dash like I am going to do to save on buying the stalk and on having to pull the airbag.
Good luck with that - those functions on the stock switch work through resistors and involve the extremely expensive central engine computer (ECM). The resistors are the squiggly lines in the diagram. It's important to know the exact values to make it work right. A familiarity with Ohm's Law would help, too.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 04-21-2009, 06:51 PM   #2
Correct. The resistor values are:
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
This is a standard way of having multiple inputs on a single wire.
Old 04-21-2009, 07:10 PM   #3
you realize CTScott is an electrical engineer right and Im a electrical engineering tech
BTW CTScott i was thinking the same thing about the switches except Im thinking of mounting them in my door armrest right above the handle, i will most likely canibalize the stalk and use jumper wires and a LED to show the status
I am soldering up a two button test rig right now. I have a Karate class at 8, so I am hoping to test on/off and Set on my way there...
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
