Old 04-22-2009, 09:35 AM   #1
xbalance
Drives: stock
how was the respond in the slow, mid, high speed when taking a corner? if continue push will it oversteer? compare to TRD bar respond?
xbalance is offline   Reply With Quote
Old 04-22-2009, 09:56 AM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Like I said, I just put it on yesterday evening and I'll know more after I've lived with it for a while and after I've autocrossed with it. I'm not going to push it hard enough to find how it handles at the limit on the street.
I can answer the last parts of your query:
"if continue push will it oversteer?" No, of course not. No way, no how, that's not how FWD cars work. If it's understeering and you keep your foot all the way on the gas, it's going to keep understeering. You won't get oversteer unless you lift or brake in a turn. With a larger rear bar, lift-throttle oversteer should be greater, however.
"compare to TRD bar respond" It's a much stiffer bar, yes, it provides better steering response than the smaller TRD bar.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
