Old 04-22-2009, 11:42 AM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Originally Posted by Creeper
yeah if your battery is low or dies on you, hope you arnt on the road or highway. you lose EVERYTHING all your lights power stearing all that fun stuff. and power stearing usually goes first for me then lights and so on. luckyly you didnt lose your ps while driving. id double check your battery connection it could just have vibrated lose or you may had just a low battery.
it's not gonna die on you unless the generator/alternator suddenly comes completely disconnected from any circuit...
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-22-2009, 11:50 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
Actually a defective voltage regulator in the altenator can allow system voltage to get low enough that the engine will die.
Old 04-22-2009, 12:15 PM   #3
Shroomster
Shroomster's Avatar
true, but I've only seen one man capable of making a regulator work incorrectly......he is also the same man who can light a car on fire with the alternator by grounding it and putting brushes in wrong...but he'll deny it till the end...
