I have no idea what the stock front sway bar size is, but I can measure it tomorrow.
The only negative is that by increasing front stiffness, you increase the chance of understeer. My car actually has some oversteer with my set up at this point (coilovers + thick rear torsion/sway bar + lighter weight in the rear), so using this front sway bar should head me back towards neutral steering, while decreasing roll at the same time. That will be an improvement. Lots of factors play into tuning a suspension, including simple stuff like tire pressure.
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Sounds good. For those that like a bit of oversteer, I guess we could just make the rear bar even thicker - How about 26-28mm????? Even less body roll.
I wonder if there is a easy way of modifying the TRD sway bar to be even stiffer than it is now. |
I used to have 1700 posts
unless u have an LSD
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| What are you doing right now? | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 26819 | 12-31-2010 10:48 AM |
| wtb fast stock front 07 lb met met bumper | AlexNet0 | Willing to Buy by private party | 0 | 02-26-2009 08:39 PM |
| Weight Savings | 03Z33 | Performance Modifications | 30 | 01-31-2009 04:14 PM |
| Wtb- a stock front bumper | Snyprwlf47 | Willing to Buy by private party | 8 | 01-09-2009 03:09 PM |
