#1 | |
![]() ![]() ![]() Drives: 05 YRS Silver Lining Metallic Join Date: Jan 2006
Just wanted to share this: turbo 1NZFE
![]() Found this, a turbo 1NZFE. The car is a Thai Vios, a Southeast Asia market-only car. It has basically the same internals as the old Echo. Here's an excerpt: Quote:
Υοu can have the same result with a TTE supercharger and you keep the warranty intact!
Very interesting and quite rare car, this vios turbo...
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
that's one of the reasons the 1NZ cant be force fed large pressures is the compression ratio...
as far as I understand shorter piston rods would reduce the compression ratio, right?
#6 | |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Better off changing the pistons to change the compression or simply rechamber the head domes.
The early bird gets the worm, but the second mouse gets the cheese. |
You'll see TRD USA with a FI option within a year in the states.
#8 | ||
#9 | |
Case in point, look at the demographic this forum feeds off of. How much money is spent on YW.com alone in a week on the Yaris aftermarket? Better yet, ask the sponsor's wallets. But yes, when TRD does come out with a FI kit, I agree... it is going to be one expensive box. |
Well it will be expensive, but you get to keep the warranty!
#11 | |
![]() Drives: Black 3dr Liftback Join Date: Jun 2006
http://www.zeropointindustries.net/s...products_id=77 |
Thicker head gaskets work as well, so long as you dont buy them from 'Freds Discount Gaskets'....
This doesnt usually net you too much in the CR department, only helps. If your going to rebuild the engine look at buying a totalled xB and pull the motor. |
#13 | ||
Just to give an impression of the performance difference with a Vios Turbo...
About a week ago, my friend and I went to pick up another friend from the airport. Keep in mind none of us are lightweights, between 80 to 90kg each. Anyway we're on the way home, my friend is driving, the other friend just shooting video of the sights, and a Vios turbo zooms past... We tried to catch up, and you can see the rest for yourself here: http://www.youtube.com/watch?v=jOa_z73WDGQ
Ha! He kicked your asses!
dude three fat guys in a yaris, with luggage... whaddaya expect?
#17 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
![]() ![]() Drives: MK I Vitz 1.0l F Package Join Date: Jun 2006
![]() I feel sorry for all you guys, we have loads of turbo Vitz here... |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
