Old 04-23-2009, 11:19 AM   #11
yarstar
Drives: 2008 Absolute Red HB
Originally Posted by MGargano View Post
I love the performance of the 1ZZ but the harsh oscillation is a killer. So I should reinstall the stock TB & chip for a week or so and then start over with the 1ZZ and chip swap?
That worked for me. You may be getting ocillation due to an air leak. Make sure you did the gasket maker correctly and really let it set up a long time (I let mine set up overnight). Check also the intake for leaks.
I pulled mine back off, waited a week, did the chip swap again, and re-installed and have had no probs since.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
