![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
ok.......
here's the deal....again...for you who will listen now you can stop the oscillation in less than ten minutes. after the swap, pull the plug on the battery, drain caps by hitting brakes and turning on lights plug in batt start car AND LET IDLE FOR 10 MINUTES you have to re-learn the iac sensor to the new throttle body...it is oscilating to learn the position of the iac motor....unless you have a vac leak somewhere. |
| 1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 06:57 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
