Old 04-24-2009, 01:32 AM   #1
YarisSedan
Drives: 08 Yaris Sedan
your spring rate wouldn't change since it equates to a force per length...you wouldn't really be changing the unsprung length of the spring and definitely not altering the force exerted.
Not if you stacked the bump stops completed so there would be practically no movement
Old 04-24-2009, 10:09 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
then you effectively removed that spring and shock from being useful, ie it wont compress or dampen. He just wants to raise the spring rate a little to compensate for weight.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-24-2009, 12:04 PM   #3
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
Originally Posted by contraband831 View Post
WTF? How big are you, I am a short, big dude...and i have my car lowered with no problems. you aint going to make the car stand on two wheels if that is what you are worried about. Another member MadDog is a Tall Big Dude, and he from what we know has no issues with his ride.
I am 6' 4" and 395 lbs, so yeah, i'm a hefty dude. No, I'm not worried about the car rollin.
Originally Posted by Klinton View Post
my buddy weights 340 pounds and drives my car fine man no left lean
My car has not yet began to lean either, however, my first and second truck did it enventually and it is only a matter of time before this little car starts to do it also
Exactly! I want the ride to semi-enjoyable but at the same time I don't want it to lean when I set in it.
Slick is offline   Reply With Quote
Old 04-24-2009, 12:09 PM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
did you look at the link i posted earlier? what you want is a spring rubber. Longacre makes them, if you watch nascar, they talk about them all the time. They are great for tuning the spring rate of each corner independently (but any change to one corner, results in slight changes to the others, but that is way beyond our scope here.)
That should be exactly what you need... now what rate you need, no idea LOL, might have to experiement a little, but they are cheap-ish, so no worries...
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Which lowering springs should I choose? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-28-2009 05:56 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
Please give me an answer to : fat and muscle hasher22 Off-topic / Other Cars / Everything else Discussions 17 09-09-2007 09:47 AM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
